<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Brightness on m5stickc &amp; core gray?]]></title><description><![CDATA[<p dir="auto">On the m5stickc, uiflow's brightness is converted to axp.setLcdBrightness(level). This appears to be between 0 and 100, although 20 is barely visible in the dark.</p>
<p dir="auto">The core gray doesn't have axp, but one can use lcd.setBrightness(level): This appears to be 0-255 <a href="https://github.com/m5stack/m5-docs/blob/master/docs/en/api/lcd.md#setbrightness" target="_blank" rel="noopener noreferrer nofollow ugc">from the doc</a>, but realistically, it doesn't seem to matter above 25 or so. Is this documented anywhere?</p>
]]></description><link>https://community.m5stack.com/topic/3849/brightness-on-m5stickc-core-gray</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 17:15:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3849.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 21 Dec 2021 03:22:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Brightness on m5stickc &amp; core gray? on Tue, 21 Dec 2021 08:52:52 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dclaar" aria-label="Profile: dclaar">@<bdi>dclaar</bdi></a></p>
<p dir="auto">I don't think this has been documented yet - but I could be wrong.</p>
<p dir="auto">But consider this. I have multiple M5Stack (Gray, Basic, Fire) and even with the same brightness setting the actual brightness differs visibly.</p>
]]></description><link>https://community.m5stack.com/post/15904</link><guid isPermaLink="true">https://community.m5stack.com/post/15904</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 21 Dec 2021 08:52:52 GMT</pubDate></item></channel></rss>
