<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to connect a NB-IOT unit to M5GoBottom (Core2)]]></title><description><![CDATA[<p dir="auto">For M5GO BOTTOM2 component and available port B what is the UART interface numbering for RX and TX signals?<br />
Want to connect an NB-IOT unit via an UART cable. I've already allocated pin 13 and 14 for the GPS unit in the stack.</p>
]]></description><link>https://community.m5stack.com/topic/3893/how-to-connect-a-nb-iot-unit-to-m5gobottom-core2</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 13:50:39 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3893.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Jan 2022 18:26:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to connect a NB-IOT unit to M5GoBottom (Core2) on Wed, 05 Jan 2022 17:31:22 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/falbriard" aria-label="Profile: falbriard">@<bdi>falbriard</bdi></a></p>
<p dir="auto">yes, port C (blue / GPIO13 / GPIO14) is blocked by the GPS module. However you can define a second serial connection in your code using port B (black / GPIO26 / GPIO36) and then connect the NB-IOT to port B.</p>
<p dir="auto">And no, using two UART (serial) modules in parallel on the same port is not possible.</p>
]]></description><link>https://community.m5stack.com/post/16072</link><guid isPermaLink="true">https://community.m5stack.com/post/16072</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 05 Jan 2022 17:31:22 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect a NB-IOT unit to M5GoBottom (Core2) on Wed, 05 Jan 2022 12:10:18 GMT]]></title><description><![CDATA[<p dir="auto">The H5Go Bottom module implements "HY2.0-4P-PortC(blue)" and by default points to GPIO13 (RXD2) and GPIO14(TXD2). The same pins are already in use by the GPS module part of the M5 Core2 stack (currently set to TX=14, RX=13). Is there a solution to operate both modules in parallel, the NB-IOT (Uart) unit and GPS module?</p>
]]></description><link>https://community.m5stack.com/post/16064</link><guid isPermaLink="true">https://community.m5stack.com/post/16064</guid><dc:creator><![CDATA[falbriard]]></dc:creator><pubDate>Wed, 05 Jan 2022 12:10:18 GMT</pubDate></item><item><title><![CDATA[Reply to How to connect a NB-IOT unit to M5GoBottom (Core2) on Tue, 04 Jan 2022 19:05:15 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/falbriard" aria-label="Profile: falbriard">@<bdi>falbriard</bdi></a></p>
<p dir="auto">you'll find your answer looking at the published <a href="https://docs.m5stack.com/en/base/m5go_bottom2" target="_blank" rel="noopener noreferrer nofollow ugc">pin-mapping</a>.</p>
]]></description><link>https://community.m5stack.com/post/16056</link><guid isPermaLink="true">https://community.m5stack.com/post/16056</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 04 Jan 2022 19:05:15 GMT</pubDate></item></channel></rss>
