<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Missing &quot;import module&quot; definition at UIFlow 1.9.0 at new Project]]></title><description><![CDATA[<p dir="auto">Using the UIFlow V 1.9.0 at server <a href="https://flow.m5stack.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://flow.m5stack.com/</a> at the function "create a new project and clear workspace"<br />
I'm not able to find the "import module" statement required for operation of the stackable GPS module. I'm able to create the "Init with custom pin TX, RX" statement selecting it from the GPS modules section, but the MicroPython code does not add the required "import module" command. This also creates a run-time error. Reverse edit from the Python syntax to UIFflow also is not allowed. Is this a bug in UIFlow or did I miss something in the GUI flow.</p>
]]></description><link>https://community.m5stack.com/topic/3899/missing-import-module-definition-at-uiflow-1-9-0-at-new-project</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 11:03:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3899.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Jan 2022 16:39:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Missing &quot;import module&quot; definition at UIFlow 1.9.0 at new Project on Thu, 06 Jan 2022 14:08:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thanks for support, problem solved.</p>
]]></description><link>https://community.m5stack.com/post/16087</link><guid isPermaLink="true">https://community.m5stack.com/post/16087</guid><dc:creator><![CDATA[falbriard]]></dc:creator><pubDate>Thu, 06 Jan 2022 14:08:56 GMT</pubDate></item><item><title><![CDATA[Reply to Missing &quot;import module&quot; definition at UIFlow 1.9.0 at new Project on Thu, 06 Jan 2022 04:15:32 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/falbriard" aria-label="Profile: falbriard">@<bdi>falbriard</bdi></a></p>
<p dir="auto">this seems to be an issue with UIFlow if the <code>Init with custom pin TX, RX</code> is the only statement. As soon as I use any of the GPS <code>Get</code> blocks, eg. <code>Get time</code> the missing <code>import module</code> line shows up.</p>
]]></description><link>https://community.m5stack.com/post/16084</link><guid isPermaLink="true">https://community.m5stack.com/post/16084</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 06 Jan 2022 04:15:32 GMT</pubDate></item></channel></rss>
