<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Atom PWM 12v output control?]]></title><description><![CDATA[<p dir="auto">Hi all - and thank you for great ESP32 products.</p>
<p dir="auto">I trying out the new Atom PWM kit and I was wondering if there's a pin to control the 12v power? I have a PWM fan that doesn't completely stop if I set the speed to 0 with GPIO22 and I would like to cut off the power to the fan.</p>
<p dir="auto">BR</p>
]]></description><link>https://community.m5stack.com/topic/3914/atom-pwm-12v-output-control</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 06:48:44 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3914.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 11 Jan 2022 12:12:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Atom PWM 12v output control? on Tue, 11 Jan 2022 15:00:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> and thanks for the quick reply.</p>
<p dir="auto">I also looked at the datasheet and came to the same conclusion. It might be easier to find a fan that supports 0 rpm with lower (&lt;10%) PWM duty cycles.</p>
]]></description><link>https://community.m5stack.com/post/16148</link><guid isPermaLink="true">https://community.m5stack.com/post/16148</guid><dc:creator><![CDATA[kya]]></dc:creator><pubDate>Tue, 11 Jan 2022 15:00:14 GMT</pubDate></item><item><title><![CDATA[Reply to Atom PWM 12v output control? on Tue, 11 Jan 2022 14:51:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/kya" aria-label="Profile: kya">@<bdi>kya</bdi></a></p>
<p dir="auto">according to the datasheet the controller IC EG27324 has an input pin (SD) which could be used to disable the output(s). However according to the <a href="https://docs.m5stack.com/en/atom/atom_pwm" target="_blank" rel="noopener noreferrer nofollow ugc">Atom PWM kit schematic</a> SD is tied to GND and not controllable via a GPIO. (Unless you modify the hardware of course.)</p>
<p dir="auto">Note: I don't have the Atom PWM kit so I cannot test if modifying the hardware and controlling SD would actually help.</p>
]]></description><link>https://community.m5stack.com/post/16147</link><guid isPermaLink="true">https://community.m5stack.com/post/16147</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 11 Jan 2022 14:51:43 GMT</pubDate></item></channel></rss>
