<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Incorrect measurements with ENV III HAT on M5StickC+]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have the impression that ENV III HAT is not working properly and is providing incorrect measurements:</p>
<p dir="auto"><img src="https://i.imgur.com/1hC6NI3.jpg" alt="M5StickC+ with ENV III HAT" class=" img-fluid img-markdown" /></p>
<p dir="auto">First, the measured temperature is about 3°C above the actual temperature (which I also checked with a DS18B20 sensor). I understand that the sensor measurement can be disturbed by the heating of the electronic components, but still... 3°C is a huge difference !</p>
<p dir="auto">I made sure to put the microcontroller in deep sleep to give it time to cool down (see my code below)!</p>
<p dir="auto">Then, the measured pressure is always equal to <strong>zero</strong>... 🤔</p>
<p dir="auto">Here is my code:</p>
<pre><code class="language-cpp">#include &lt;M5Unified.h&gt;
#include &lt;UNIT_ENV.h&gt;
constexpr uint32_t SLEEP_DURATION_US = 60 * 1000 * 1000; // 1 min
SHT3X   sht30;
QMP6988 qmp6988;
    M5.begin();
    M5.Display.setRotation(3);
    M5.Display.setFont(&amp;fonts::Font2);
    Wire.begin(0, 26);
    qmp6988.init();
    static float_t temperature, humidity, pressure;
    uint8_t fail = sht30.get();
    temperature = fail ? 0 : sht30.cTemp;
    humidity    = fail ? 0 : sht30.humidity;
    pressure    = qmp6988.calcPressure();
    qmp6988.setpPowermode(QMP6988_SLEEP_MODE);
    M5.Display.drawString("T:", 10, 10); M5.Display.drawFloat(temperature, 2, 30, 10);
    M5.Display.drawString("H:", 10, 30); M5.Display.drawFloat(humidity,    2, 30, 30);
    M5.Display.drawString("P:", 10, 50); M5.Display.drawFloat(pressure,    2, 30, 50);
    delay(2000);
    M5.Power.Axp192.setLDO2(0);
    esp_sleep_enable_timer_wakeup(SLEEP_DURATION_US);
    esp_deep_sleep_start();
<p dir="auto">Did I make a mistake somewhere?</p>
<p dir="auto">Maybe you have experienced this sensor yourself and have some elements to share with me?</p>
<p dir="auto">Thank you very much in advance.<br />
Steph</p>
]]></description><link>https://community.m5stack.com/topic/3929/incorrect-measurements-with-env-iii-hat-on-m5stickc</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 16:23:55 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3929.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 15 Jan 2022 21:03:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Mon, 28 Aug 2023 18:33:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/teflon121" aria-label="Profile: teflon121">@<bdi>teflon121</bdi></a> If you are measuring temperature in an environment where the temperature is stable such as at my desk(!) you can, for sure, just add an "offset". Just measure the ambient with a known and trusted thermometer and add or subtract this to the raw measurement.<br />
If the device is going to be subjected to a wide range of temps, then you need to see if offset is satisfactory over that range.<br />
If not...the second half of calibration is "span" which is accomplished by multiply or dividing the raw measurement. This gets fiddly and can be enjoyable like tuning a carburetor!<br />
display = raw * span + offset, or depending on characteristics of the sensor, display = (raw + offset) * span<br />
Span is usually a very low number like 1.2 or 0.98<br />
-Terry</p>
]]></description><link>https://community.m5stack.com/post/22084</link><guid isPermaLink="true">https://community.m5stack.com/post/22084</guid><dc:creator><![CDATA[teastain]]></dc:creator><pubDate>Mon, 28 Aug 2023 18:33:40 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sun, 27 Aug 2023 17:13:12 GMT]]></title><description><![CDATA[<p dir="auto">You will need to find the data sheet for the temperature sensor used in the unit as I have no idea how to make the numbers for calibration.</p>
]]></description><link>https://community.m5stack.com/post/22083</link><guid isPermaLink="true">https://community.m5stack.com/post/22083</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 27 Aug 2023 17:13:12 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sun, 27 Aug 2023 15:14:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thank you so much! this is very helpful.</p>
<p dir="auto">Could I also ask you to point me in a direction for the calibration formula or a small description of the theory behind calibrating it ?  in my head I just feel like chopping 3 degrees off the reading would almost suffice, but Im sure there is a more eloquent method.  Ultimately if I can figure it out, sleeping code will be needed for longer run times in terms of battery longevity. This seemingly also would help a bit with accurate temps.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://community.m5stack.com/post/22082</link><guid isPermaLink="true">https://community.m5stack.com/post/22082</guid><dc:creator><![CDATA[teflon121]]></dc:creator><pubDate>Sun, 27 Aug 2023 15:14:52 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sun, 27 Aug 2023 07:21:10 GMT]]></title><description><![CDATA[<p dir="auto">When I mean different pins, I mean that they use different IO pins when connected to the sticks.<br />
Units use GPIO32/33 on the StickCplus where as the hats use G26/G36/G25/G0 on the Hat connector.</p>
<p dir="auto">The sensors have been proved not to be fully realible and need calibrating, tuning in code in order to work in the environment you intend them to work in.</p>
<p dir="auto">As to the I2C address issue. If you have more than 1 device on the bus with the same i2c address, the data received by the sticks could be corrupted, the bus may stop working or data recorded will be very inaccurate.</p>
]]></description><link>https://community.m5stack.com/post/22081</link><guid isPermaLink="true">https://community.m5stack.com/post/22081</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 27 Aug 2023 07:21:10 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sat, 26 Aug 2023 04:27:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> this is great info!</p>
<p dir="auto">I did start to understand the 0x56 addresse and 0x44 I think it is.. it seems like the addresses were the same in the technical manuals, but maybe that has no bearing on what you are saying ?<br />
Im guessing the wire. commands Im seeing would be for the non hat version ?</p>
<p dir="auto">Ill start looking for the difference in the pins and maybe be able to learn something again!</p>
<p dir="auto">Again, Im a super newb and I appreciate the help.</p>
<p dir="auto">I originally found this thread because my envIII hat temperature reading just cant be true.   it seems a bit high and sort of climbs at time and peaks around 29 degrees.  I suspect its the working temperature of the M5stick. screen heat I guess?</p>
]]></description><link>https://community.m5stack.com/post/22071</link><guid isPermaLink="true">https://community.m5stack.com/post/22071</guid><dc:creator><![CDATA[teflon121]]></dc:creator><pubDate>Sat, 26 Aug 2023 04:27:42 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Fri, 25 Aug 2023 06:04:40 GMT]]></title><description><![CDATA[<p dir="auto">ENVIII and ENVIIIHat are NOT the same thing and as such use different pins</p>
<p dir="auto">ENVIII uses the port on the bottom of the stick whereas the HAT use the pins on the top of the stick.</p>
]]></description><link>https://community.m5stack.com/post/22059</link><guid isPermaLink="true">https://community.m5stack.com/post/22059</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 25 Aug 2023 06:04:40 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Thu, 24 Aug 2023 00:21:58 GMT]]></title><description><![CDATA[<p dir="auto">I know Im posting on an old thread, but the information for these things are hard to come by.</p>
<p dir="auto">Im a newb, but sort of know what Im looking at with this code.</p>
<p dir="auto">But Im unable to get this running on my M5stickCplus with ENVIII<br />
even with the help for ENVIII in the code the // comments I cant get this working.  I get the screen blink every 30 seconds, which I dialed down to ten seconds, and it blinks no readings, all at 0.00</p>
<p dir="auto">What am I missing here?  I also couldnt find M5_env.h  and used m5stack_ENV.h from the install libraries,  assuming they are the same ?</p>
<p dir="auto">Thanks for any help. Especially thanks to the OP for his code here, looks promising, helping me learn a lot.</p>
]]></description><link>https://community.m5stack.com/post/22042</link><guid isPermaLink="true">https://community.m5stack.com/post/22042</guid><dc:creator><![CDATA[teflon121]]></dc:creator><pubDate>Thu, 24 Aug 2023 00:21:58 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sun, 16 Jan 2022 11:45:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/northwest" aria-label="Profile: northwest">@<bdi>northwest</bdi></a> Ok Lee, thank you very much, that's very kind of you 🙂</p>
]]></description><link>https://community.m5stack.com/post/16227</link><guid isPermaLink="true">https://community.m5stack.com/post/16227</guid><dc:creator><![CDATA[m1cr0lab]]></dc:creator><pubDate>Sun, 16 Jan 2022 11:45:54 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sun, 16 Jan 2022 11:38:58 GMT]]></title><description><![CDATA[<p dir="auto">At the moment, I try to control the radiators in the house with this ENVIII. I have diffrent meassuring instruments here, I will check next week how they are to compare with the ENVIII</p>
]]></description><link>https://community.m5stack.com/post/16226</link><guid isPermaLink="true">https://community.m5stack.com/post/16226</guid><dc:creator><![CDATA[northwest]]></dc:creator><pubDate>Sun, 16 Jan 2022 11:38:58 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sun, 16 Jan 2022 11:11:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/northwest" aria-label="Profile: northwest">@<bdi>northwest</bdi></a>, you're right, I have to check.</p>
<p dir="auto">Unfortunately I misplaced the manual, but I did find <a href="https://www.aroma-zone.com/cms/sites/default/files/GC031-Notice-thermometre-digital.pdf" target="_blank" rel="noopener noreferrer nofollow ugc">this summary doc</a> online. It states the following features:</p>
<li>Accuracy : -20-100°C +/- 1°C</li>
<li>Resolution : 0.1°C</li>
<p dir="auto">Nevertheless, I have a couple of DS18B20 sensors, which are known to be pretty accurate, all of which indicate a temperature very close to that measured by my kitchen thermometer.</p>
<p dir="auto">An error close to 1°C is acceptable in my use case, but ENV II or ENV III HATs get worse measurements than my DS18B20. I also compared these measurements with other sensors like the Adafruit BME280 (which always gives measurements with a 2°C increase because of the voltage regulator on the sensor board), but which is still accurate when taken into account.</p>
<p dir="auto">Thank you,<br />
Steph</p>
]]></description><link>https://community.m5stack.com/post/16225</link><guid isPermaLink="true">https://community.m5stack.com/post/16225</guid><dc:creator><![CDATA[m1cr0lab]]></dc:creator><pubDate>Sun, 16 Jan 2022 11:11:34 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sun, 16 Jan 2022 09:43:39 GMT]]></title><description><![CDATA[<p dir="auto">Hello<br />
Witch tolerances does your AZ device have? Must been shown in the manual.<br />
Lee</p>
]]></description><link>https://community.m5stack.com/post/16218</link><guid isPermaLink="true">https://community.m5stack.com/post/16218</guid><dc:creator><![CDATA[northwest]]></dc:creator><pubDate>Sun, 16 Jan 2022 09:43:39 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sun, 16 Jan 2022 08:39:32 GMT]]></title><description><![CDATA[<p dir="auto">Glad you worked it out.</p>
]]></description><link>https://community.m5stack.com/post/16213</link><guid isPermaLink="true">https://community.m5stack.com/post/16213</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 16 Jan 2022 08:39:32 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sat, 15 Jan 2022 23:31:16 GMT]]></title><description><![CDATA[<p dir="auto">Well... I'm soooooo sorry... I thought I had an ENV III, but it's actually an ENV II... 😬</p>
<p dir="auto">ENV II even has two temperature sensors, since instead of the QMP6988, it has a BMP280, which is a pressure <strong>and</strong> temperature sensor. It is, therefore, possible to perform 2 simultaneous temperature measurements!</p>
<p dir="auto">So, this time things work better:</p>
<p dir="auto"><img src="https://i.imgur.com/0XUEyuA.jpg" alt="ENV II with M55StickC+" class=" img-fluid img-markdown" /></p>
<p dir="auto">We still notice a difference in the temperature measurements. The SHT30 seems to get better results (which is probably why they added it).</p>
<p dir="auto">Here, it's still 1°C above the real temperature. In the meantime, I turned on the air-conditioning, so maybe the deviation is reduced because of the ventilation? On the other hand, we can see that the temperature measured by the BMP280 is 1°C higher than the one measured by the SHT30.</p>
<p dir="auto">But this time, I get a non-zero pressure measurement. 🙂</p>
<p dir="auto">Here is the new version of my code for those who are interested:</p>
#include &lt;Adafruit_BMP280.h&gt;
constexpr uint32_t SLEEP_DURATION_US = 30 * 1000 * 1000; // 30 sec
SHT3X sht30;
Adafruit_BMP280 bmp;
// QMP6988 qmp6988; // only for ENV III
    M5.begin();
    Wire.begin(0, 26);
    bmp.begin(0x76);
    bmp.setSampling(
        Adafruit_BMP280::MODE_NORMAL,
        Adafruit_BMP280::SAMPLING_X16,
        Adafruit_BMP280::FILTER_X16,
        Adafruit_BMP280::STANDBY_MS_500
    // qmp6988.init(); // only for ENV III
void displayMeasurement(
    const uint8_t x1,
    const uint8_t x2,
    const uint8_t x3,
    const uint8_t y,
    const char*   sensor,
    const char*   data,
    const float_t value
    M5.Display.drawString(sensor,  x1, y);
    M5.Display.drawString(data,    x2, y);
    M5.Display.drawFloat(value, 2, x3, y);
    static float_t temperature_1, temperature_2, humidity, pressure;
    temperature_1 = bmp.readTemperature();
    temperature_2 = fail ? 0 : sht30.cTemp;
    pressure      = bmp.readPressure();
    // only for ENV III
    // pressure = qmp6988.calcPressure();
    // qmp6988.setpPowermode(QMP6988_SLEEP_MODE);
    displayMeasurement(10, 70, 100, 10, "BMP280", "T1", temperature_1);
    displayMeasurement(10, 70, 100, 30, "SHT30",  "T2", temperature_2);
    displayMeasurement(10, 70, 100, 50, "SHT30",  "H",  humidity);
    displayMeasurement(10, 70, 100, 70, "BMP280", "P",  pressure);
    delay(2000);
    M5.Power.deepSleep(SLEEP_DURATION_US);
<p dir="auto">Sorry for my confusion between ENV II and ENV III. But maybe finally the questions raised here will be useful to some readers...</p>
]]></description><link>https://community.m5stack.com/post/16211</link><guid isPermaLink="true">https://community.m5stack.com/post/16211</guid><dc:creator><![CDATA[m1cr0lab]]></dc:creator><pubDate>Sat, 15 Jan 2022 23:31:16 GMT</pubDate></item><item><title><![CDATA[Reply to Incorrect measurements with ENV III HAT on M5StickC+ on Sat, 15 Jan 2022 21:33:19 GMT]]></title><description><![CDATA[<p dir="auto">I apparently get a small improvement in the temperature measurement by shutting down the microcontroller like this:</p>
<pre><code class="language-cpp">    // M5.Power.Axp192.setLDO2(0);
    // esp_sleep_enable_timer_wakeup(SLEEP_DURATION_US);
    // esp_deep_sleep_start();
<p dir="auto">But I still have a 2.5°C difference...</p>
<p dir="auto">On the other hand, I don't have a solution for the pressure measurement. 😕</p>
]]></description><link>https://community.m5stack.com/post/16204</link><guid isPermaLink="true">https://community.m5stack.com/post/16204</guid><dc:creator><![CDATA[m1cr0lab]]></dc:creator><pubDate>Sat, 15 Jan 2022 21:33:19 GMT</pubDate></item></channel></rss>
