<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MicroPython lcd.qrcode is not work]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">Please let me ask a question about microPython.</p>
<p dir="auto">Regular M5 Cloud no<br />
MicroPython does not have lcd.qrcode.<br />
<a href="https://github.com/m5stack/M5Cloud#lcd" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Cloud#lcd</a><br />
However, M5 Flow UI has lcd.qrcode.</p>
<p dir="auto">Is there a way to use lcd.qrcode with M5 Cloud?<br />
Is there specification information on lcd.qrcode of M5 Flow UI?</p>
]]></description><link>https://community.m5stack.com/topic/393/micropython-lcd-qrcode-is-not-work</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 04:56:34 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/393.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Nov 2018 08:27:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MicroPython lcd.qrcode is not work on Wed, 14 Nov 2018 07:16:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a> 在 <a href="/post/1947">MicroPython lcd.qrcode is not work</a> 中说：</p>
<p dir="auto">uiflow</p>
<p dir="auto">Thank you for your reply!<br />
By your explanation, I understand that there is a difference between the two services.</p>
<p dir="auto">I was thinking of using M5 Cloud Offline to use M5 Stack offline.</p>
<p dir="auto">I usually use Python, so I wanted to use microPython.</p>
<p dir="auto">However, given the richness of the library, I felt it should be implemented with cpp.</p>
<p dir="auto">In the future, if microPython 's functions are enhanced, I would like to try again.</p>
]]></description><link>https://community.m5stack.com/post/1985</link><guid isPermaLink="true">https://community.m5stack.com/post/1985</guid><dc:creator><![CDATA[komikoni]]></dc:creator><pubDate>Wed, 14 Nov 2018 07:16:21 GMT</pubDate></item><item><title><![CDATA[Reply to MicroPython lcd.qrcode is not work on Thu, 08 Nov 2018 02:52:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/komikoni" aria-label="Profile: komikoni">@<bdi>komikoni</bdi></a> Hi and sorry for the late reply. I tested myself and you are correct the lcd.qrcode is missing from the m5cloud firmware. I had a look in the REPL and noticed it was missing.<br />
see this screenshot <a href="https://ibb.co/njC2aA" target="_blank" rel="noopener noreferrer nofollow ugc">https://ibb.co/njC2aA</a></p>
<p dir="auto">As the small development team we have has been fully focusing its efforts on Ui flow firmware of late I cannot foresee the m5cloud firmware being updated any time soon.</p>
<p dir="auto">I was wondering since uiflow is more feature rich than cloud now I was wondering why you prefer cloud over uiflow</p>
<p dir="auto">I'm sure you already figured it out but the lcd.qrcode command is used in this way</p>
<p dir="auto">lcd.qrcode('insert web url here', xposition, yposition, scale factor)</p>
<p dir="auto">for example</p>
<p dir="auto">lcd.qrcode('<a href="https://microsoft.com" target="_blank" rel="noopener noreferrer nofollow ugc">https://microsoft.com</a>', 72, 32, 176)</p>
<p dir="auto">hope that helped, I will look into the problem to see if there are any alternative solutions</p>
]]></description><link>https://community.m5stack.com/post/1947</link><guid isPermaLink="true">https://community.m5stack.com/post/1947</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 08 Nov 2018 02:52:13 GMT</pubDate></item></channel></rss>
