<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unit CatM]]></title><description><![CDATA[<p dir="auto">There is no serial response from this unit. No answer to AT @ 115200. Any idea?</p>
]]></description><link>https://community.m5stack.com/topic/3987/unit-catm</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 14:08:50 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/3987.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Feb 2022 22:37:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unit CatM on Wed, 02 Feb 2022 08:20:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ckuehnel" aria-label="Profile: ckuehnel">@<bdi>ckuehnel</bdi></a></p>
<p dir="auto">could you share some additional information? E.g.</p>
<li>which M5Stack core is it connected to?</li>
<li>which Groove port are you using?</li>
<li>how do you initialize the serial connection?</li>
<li>which GPIOs are you using for TX and RX?</li>
<li>could you share your UiFlow or Arduino code?</li>
<p dir="auto">Also these SIM7xxx modems take some time to initialize before they react to AT commands. Try sending the AT command a couple of times.</p>
]]></description><link>https://community.m5stack.com/post/16473</link><guid isPermaLink="true">https://community.m5stack.com/post/16473</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 02 Feb 2022 08:20:54 GMT</pubDate></item></channel></rss>
