<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Fire will not pass special characters correctly on password when signing into WiFi for initial setup]]></title><description><![CDATA[<p dir="auto">When first connecting to your home gateway, the M5GO software that comes with the M5Stack Fire does not work with special characters. For example if you enter a "#"in the password, the software sends it to the gateway as an ASCII string and the router does not accept it. I had to change the router WiFi password to all letters and numbers to setup the M5Stack Fire when it first arrived.</p>
]]></description><link>https://community.m5stack.com/topic/399/m5stack-fire-will-not-pass-special-characters-correctly-on-password-when-signing-into-wifi-for-initial-setup</link><generator>RSS for Node</generator><lastBuildDate>Sun, 10 May 2026 07:08:15 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/399.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Nov 2018 01:52:08 GMT</pubDate><ttl>60</ttl></channel></rss>
