<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Switch back to UIFlow cloud update using only REPL]]></title><description><![CDATA[<p dir="auto">I would like to know if there was a way to switch from a loaded and running user app back to UIFlow web update to send a new app from the web interface without touching the LCD. I would like to switch modes using only the REPL interface.</p>
<p dir="auto">I have a device at another location that I only have access to via it's usb port connected to a machine I am VNC'd into. I can access the serial port over USB and get to the REPL interface. The Core2 is running an app I made using UIFLow and I would like to return the Core2 back to UIFlow update over wifi.</p>
<p dir="auto">Normally if i were at the unit I would press reset, touch "flow" then touch "wifi". I would like to replicate this via the REPL interface as I do not have physical access to the LCD.</p>
<p dir="auto">Is this possible?</p>
]]></description><link>https://community.m5stack.com/topic/4001/switch-back-to-uiflow-cloud-update-using-only-repl</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 22:36:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4001.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Feb 2022 10:54:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Switch back to UIFlow cloud update using only REPL on Sat, 05 Feb 2022 03:22:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thank you, I forgot about that. It’s a perfect work around to what I’m trying to do. Ideally not install anything on remote machine but you gotta do what you gotta do sometimes.</p>
]]></description><link>https://community.m5stack.com/post/16530</link><guid isPermaLink="true">https://community.m5stack.com/post/16530</guid><dc:creator><![CDATA[wkibler]]></dc:creator><pubDate>Sat, 05 Feb 2022 03:22:39 GMT</pubDate></item><item><title><![CDATA[Reply to Switch back to UIFlow cloud update using only REPL on Fri, 04 Feb 2022 12:03:59 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wkibler" aria-label="Profile: wkibler">@<bdi>wkibler</bdi></a></p>
<p dir="auto">I don't know about REPL but I know you can use M5Burner's Configuration button to switch back to UiFlow web update.</p>
]]></description><link>https://community.m5stack.com/post/16525</link><guid isPermaLink="true">https://community.m5stack.com/post/16525</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 04 Feb 2022 12:03:59 GMT</pubDate></item></channel></rss>
