<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RoverC set-pulse command description?]]></title><description><![CDATA[<p dir="auto">What's the <em>purpose of-</em> and <em>valid values for-</em> the <strong>set-pulse</strong> commands?</p>
<p dir="auto">The <a href="https://docs.m5stack.com/en/hat/hat-roverc?id=protocol" target="_blank" rel="noopener noreferrer nofollow ugc">docs</a> only tell about motor speed taking values -127 to +127</p>
]]></description><link>https://community.m5stack.com/topic/4002/roverc-set-pulse-command-description</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 08:41:48 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4002.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Feb 2022 13:35:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RoverC set-pulse command description? on Tue, 08 Feb 2022 09:46:32 GMT]]></title><description><![CDATA[<p dir="auto">They actually operate on the same register, this block is used to operate independent wheels, there may be some translatione problems ( use <code>pulse</code>  less accurate ). The parameter range is -127 to +127.  we will update it later, thank you feedback.</p>
]]></description><link>https://community.m5stack.com/post/16573</link><guid isPermaLink="true">https://community.m5stack.com/post/16573</guid><dc:creator><![CDATA[m5stack]]></dc:creator><pubDate>Tue, 08 Feb 2022 09:46:32 GMT</pubDate></item></channel></rss>
