<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I connect the Unit LoRaWAN915 to an ATOMIC GPS Module?]]></title><description><![CDATA[<p dir="auto">I have an ATOMIC SPS device and would like to connect the Unit LoRaWAN915 to it. Is that possible and has anyone had any luck doing it?</p>
]]></description><link>https://community.m5stack.com/topic/4040/can-i-connect-the-unit-lorawan915-to-an-atomic-gps-module</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:06:06 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4040.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 13 Feb 2022 18:34:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I connect the Unit LoRaWAN915 to an ATOMIC GPS Module? on Fri, 29 Apr 2022 07:32:33 GMT]]></title><description><![CDATA[<p dir="auto">I also have an Atom GPS module and a LoRaWAN868 module. I plan to use both of them together to track my bike. I already got the GPS running using ESPHome. Unfortunately there seems to be no LoRa integration into ESPHome.</p>
]]></description><link>https://community.m5stack.com/post/17327</link><guid isPermaLink="true">https://community.m5stack.com/post/17327</guid><dc:creator><![CDATA[Hafenstrand]]></dc:creator><pubDate>Fri, 29 Apr 2022 07:32:33 GMT</pubDate></item><item><title><![CDATA[Reply to Can I connect the Unit LoRaWAN915 to an ATOMIC GPS Module? on Thu, 21 Apr 2022 18:28:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wwhite" aria-label="Profile: wwhite">@<bdi>wwhite</bdi></a> did you manage to send GPS signals? Could you share what your setup looks like, please?</p>
]]></description><link>https://community.m5stack.com/post/17239</link><guid isPermaLink="true">https://community.m5stack.com/post/17239</guid><dc:creator><![CDATA[samak]]></dc:creator><pubDate>Thu, 21 Apr 2022 18:28:16 GMT</pubDate></item><item><title><![CDATA[Reply to Can I connect the Unit LoRaWAN915 to an ATOMIC GPS Module? on Thu, 17 Feb 2022 06:40:06 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wwhite" aria-label="Profile: wwhite">@<bdi>wwhite</bdi></a></p>
<p dir="auto">cool. Thank you for sharing and letting me (us) know. I am looking forward to hearing about the result of the combined setup.</p>
]]></description><link>https://community.m5stack.com/post/16681</link><guid isPermaLink="true">https://community.m5stack.com/post/16681</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 17 Feb 2022 06:40:06 GMT</pubDate></item><item><title><![CDATA[Reply to Can I connect the Unit LoRaWAN915 to an ATOMIC GPS Module? on Wed, 16 Feb 2022 18:02:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> I purchased a M5Stack LoRaWan 915mhz device and connected it to the Atom and was able to connect and send data to the Helium network <a href="https://www.helium.com/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.helium.com/</a> now I need to see if I can get it going with the GPS too.</p>
]]></description><link>https://community.m5stack.com/post/16674</link><guid isPermaLink="true">https://community.m5stack.com/post/16674</guid><dc:creator><![CDATA[wwhite]]></dc:creator><pubDate>Wed, 16 Feb 2022 18:02:29 GMT</pubDate></item><item><title><![CDATA[Reply to Can I connect the Unit LoRaWAN915 to an ATOMIC GPS Module? on Mon, 14 Feb 2022 13:14:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Thanks for the input. I wasn't sure what could be connected to the Grove port and didn't want to just plug in the LoRaWAN module and damage the Atom. I'm going to give it a go. Thanks again.</p>
]]></description><link>https://community.m5stack.com/post/16650</link><guid isPermaLink="true">https://community.m5stack.com/post/16650</guid><dc:creator><![CDATA[wwhite]]></dc:creator><pubDate>Mon, 14 Feb 2022 13:14:08 GMT</pubDate></item><item><title><![CDATA[Reply to Can I connect the Unit LoRaWAN915 to an ATOMIC GPS Module? on Mon, 14 Feb 2022 11:35:17 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wwhite" aria-label="Profile: wwhite">@<bdi>wwhite</bdi></a></p>
<p dir="auto">the ATOMIC GPS module has its Groove connector unused, so yes you should be able to connect almost any unit (including the LoRaWAN915 unit) to it.</p>
<p dir="auto">If not already done then I suggest you try the ATOMIC GPS module on its own first. Then disconnect the M5Atom from the GPS module and connect the LoRaWAN915 unit via Groove connector to the M5Atom and test that on its own as well. If you are happy with the results of each then try to combine the two.</p>
]]></description><link>https://community.m5stack.com/post/16647</link><guid isPermaLink="true">https://community.m5stack.com/post/16647</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 14 Feb 2022 11:35:17 GMT</pubDate></item></channel></rss>
