<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Product Selector?]]></title><description><![CDATA[<p dir="auto">We are just discovering M5Stack and a little overwhelmed by the platform.  Our goal is to monitor some old level controllers that control a freezer compressor.  We need to simply measure 1) an NTC temperature sensor (hopefully fine measuring voltage across the loop) and 2) whether a 220V compressor is on (flagging whether a current loop is above a threshold should be fine) every 5 seconds.  We could e.g. use MQTT over WiFi and we already have a way to get MQTT to an InfluxDB database to Grafana.</p>
<p dir="auto">A few more details - it can be a wet environment (but presumably we could fit the M5Stack inside the electrical box where the current level controller is), and there is a 24 VAC supply available if we can rectify that easily to 5VDC.  I don't think we need much user input / touch screen input, but at some point I'd like to learn that on the platform too, since it could be fun.</p>
<p dir="auto">There seem to be a lot of different options - cores, sticks, atoms - is there an updated chart that would help us narrow down how and/or where to get started?  In the store there is a "Solutions" section that seems promising - it talks about "Smart Factory" which is close to what we are looking for, but there are no M5Stack controllers there that it recommends, just high level descriptions of a problem.</p>
<p dir="auto">Thanks in advance!</p>
]]></description><link>https://community.m5stack.com/topic/4050/m5stack-product-selector</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 04:16:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4050.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Feb 2022 22:03:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Product Selector? on Thu, 17 Feb 2022 15:37:05 GMT]]></title><description><![CDATA[<p dir="auto">The controller would need to be mounted outside where it won’t suffer from atmospheric changes. The Atom or the stamp will work if you just want to read a sensor and send MQTT messages to a server. What “wet” zone thermistors have you looked at? And as to monitoring rhe compressor, you could even get away with a microphone if the compressor is not also damp.</p>
]]></description><link>https://community.m5stack.com/post/16691</link><guid isPermaLink="true">https://community.m5stack.com/post/16691</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 17 Feb 2022 15:37:05 GMT</pubDate></item></channel></rss>
