<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Core : example speak.ino don&#x27;t work anymore]]></title><description><![CDATA[<p dir="auto">I need just a simple Beep for my Project and so I extract the tone from the example. After updating the Board-Software in the Arduino IDE no Beep or DingDong came out of my M5Core2. Has anyone a solution? I know that this topic was discussed before. But there is still no solutuion to produce a simple Beep/Tone on the M5Core2! Please help</p>
]]></description><link>https://community.m5stack.com/topic/4072/m5core-example-speak-ino-don-t-work-anymore</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:29:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4072.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Feb 2022 13:47:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Core : example speak.ino don&#x27;t work anymore on Fri, 25 Feb 2022 13:45:36 GMT]]></title><description><![CDATA[<p dir="auto">Check out the speak.ino  in  the new M5Unified library v0.0.5<br />
it will compile with the Core2 or the Tough and produce sound.</p>
<p dir="auto">There is a M5 speaker class , that can be used to produce tones.</p>
<p dir="auto">The problem is that while the library works by  itself<br />
it is Not compatible<br />
with  M5Tough.h  or M5Core2.h files.</p>
<p dir="auto">And yes , there is a problem with the Core2 and Tough speak.ino<br />
the Log file shows a conflict with mclk  pin config  , when trying to setup the I2S sound<br />
The error is in a higher level M5 system file that was introduced when the Tough was released in the Fall.<br />
Sorry , I dont know how to fix it..</p>
<p dir="auto">-Brent</p>
]]></description><link>https://community.m5stack.com/post/16772</link><guid isPermaLink="true">https://community.m5stack.com/post/16772</guid><dc:creator><![CDATA[SkyNorth]]></dc:creator><pubDate>Fri, 25 Feb 2022 13:45:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5Core : example speak.ino don&#x27;t work anymore on Thu, 24 Feb 2022 04:36:07 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/carusa2" aria-label="Profile: Carusa2">@<bdi>Carusa2</bdi></a></p>
<p dir="auto">have you checked the debug log? Is there an error when you run the speak.ino example?</p>
]]></description><link>https://community.m5stack.com/post/16756</link><guid isPermaLink="true">https://community.m5stack.com/post/16756</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 24 Feb 2022 04:36:07 GMT</pubDate></item></channel></rss>
