<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5StickC-Plus issue with integrated LED]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have M5StickC-Plus with UIFlow V1.9.2 and<br />
when I follow the tutorial to turn on the led, it's the ir transmitter that lights up. I see it while filming with my smartphone.</p>
<p dir="auto">I reflashed the factorytest and the ir transmitter does not light up when I am on the ir test program.</p>
<p dir="auto">Could there be an address error for the LED and the ir transmitter?</p>
]]></description><link>https://community.m5stack.com/topic/4086/m5stickc-plus-issue-with-integrated-led</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 01:59:29 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4086.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 Feb 2022 20:45:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5StickC-Plus issue with integrated LED on Sat, 26 Feb 2022 17:04:09 GMT]]></title><description><![CDATA[<p dir="auto">It could be the pins are wrong, The IR is on GPIO9 and the red on gpio10.</p>
]]></description><link>https://community.m5stack.com/post/16784</link><guid isPermaLink="true">https://community.m5stack.com/post/16784</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 26 Feb 2022 17:04:09 GMT</pubDate></item><item><title><![CDATA[Reply to M5StickC-Plus issue with integrated LED on Sat, 26 Feb 2022 05:52:37 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/kinou3000" aria-label="Profile: Kinou3000">@<bdi>Kinou3000</bdi></a></p>
<p dir="auto">on my M5StickCPlus the visible LED turns on / off as it should using the blocks <code>LED - LED ON</code> and <code>LED - LED OFF</code>. So I am not sure what is going on.</p>
<p dir="auto">BTW: the visible LED (red) is closer to the edge of the M5StickCPlus.</p>
]]></description><link>https://community.m5stack.com/post/16780</link><guid isPermaLink="true">https://community.m5stack.com/post/16780</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 26 Feb 2022 05:52:37 GMT</pubDate></item></channel></rss>
