<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Stamp C3 -&gt; Which Flash Mode to choose in Arduino IDE]]></title><description><![CDATA[<p dir="auto">Hey mates,</p>
<p dir="auto">can someone point me out which Flash Mode i should use for the M5 Stamp C3 in Arduino IDE?<br />
QIO, DIO, QOUT or DOUT</p>
<p dir="auto">any help would be great !!</p>
<p dir="auto">Thx &amp; cheers.....</p>
]]></description><link>https://community.m5stack.com/topic/4111/m5-stamp-c3-which-flash-mode-to-choose-in-arduino-ide</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 03:33:33 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4111.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Mar 2022 13:52:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Stamp C3 -&gt; Which Flash Mode to choose in Arduino IDE on Fri, 04 Apr 2025 10:14:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/knobsi" aria-label="Profile: Knobsi">@<bdi>Knobsi</bdi></a> Hi, your question is already two years old. I guess you'll have found the answer, however I just came across it today. I want to share with you an experience I had yesterday:</p>
<p dir="auto">Suddenly I encountered a problem after upgrading the Arduino IDE from v2.3.4 to v2.3.5.</p>
<p dir="auto">The board that I use is an M5 Atom Echo which has an ESP32-PICO processor.</p>
<p dir="auto">After compiling and building a sketch, that compiled, built, and ran OK with v2.3.4,<br />
It crashed after compiling and building and running with v2.3.5.</p>
<p dir="auto">In the crash report I saw "DIO".<br />
In Arduino v2.3.5 I checked the setting: &gt; Tools &gt; Flash Mode.<br />
I saw that the Flash Mode was set for: "QIO".<br />
After I changed the setting Flash Mode it to DIO, re-compiling and building, the sketch ran OK.</p>
<p dir="auto">Regards,<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/paulskpt" aria-label="Profile: Paulskpt">@<bdi>Paulskpt</bdi></a></p>
]]></description><link>https://community.m5stack.com/post/28795</link><guid isPermaLink="true">https://community.m5stack.com/post/28795</guid><dc:creator><![CDATA[Paulskpt]]></dc:creator><pubDate>Fri, 04 Apr 2025 10:14:03 GMT</pubDate></item></channel></rss>
