<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mis-match between M5stack Core2 version and flow.m5stack.com]]></title><description><![CDATA[<p dir="auto">My device has 1.9.3 but when I go to <a href="http://flow.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">flow.m5stack.com</a> I see 1.4.5  I have run M5Burn a couple of times.  How do I fix this?  Thanks.</p>
]]></description><link>https://community.m5stack.com/topic/4124/mis-match-between-m5stack-core2-version-and-flow-m5stack-com</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:06:07 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4124.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Mar 2022 15:32:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mis-match between M5stack Core2 version and flow.m5stack.com on Sun, 20 Mar 2022 16:37:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Ok, so I'm using the Web IDE successfully but only in WiFi mode, I can't figure out how to connect a USB device while using web IDE, only desktop IDE (which I understand now is no longer maintained).  I am doing this because for use in a school environment they only have "captive" WiFi.</p>
]]></description><link>https://community.m5stack.com/post/16961</link><guid isPermaLink="true">https://community.m5stack.com/post/16961</guid><dc:creator><![CDATA[david-bethesda]]></dc:creator><pubDate>Sun, 20 Mar 2022 16:37:03 GMT</pubDate></item><item><title><![CDATA[Reply to Mis-match between M5stack Core2 version and flow.m5stack.com on Thu, 17 Mar 2022 17:52:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/david-bethesda" aria-label="Profile: david-bethesda">@<bdi>david-bethesda</bdi></a> sorry, replied on a mobile and it got garbled.</p>
]]></description><link>https://community.m5stack.com/post/16949</link><guid isPermaLink="true">https://community.m5stack.com/post/16949</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 17 Mar 2022 17:52:37 GMT</pubDate></item><item><title><![CDATA[Reply to Mis-match between M5stack Core2 version and flow.m5stack.com on Thu, 17 Mar 2022 17:05:32 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/david-bethesda" aria-label="Profile: david-bethesda">@<bdi>david-bethesda</bdi></a></p>
<p dir="auto">I think you might have misread <a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>'s answer. What he meant is to use the <strong>web</strong> UI (because the Desktop <strong>app</strong> version is out of date).</p>
<p dir="auto">Note: the Desktop app version has not been updated in ages - I would <strong>not</strong> recommend to use it.</p>
]]></description><link>https://community.m5stack.com/post/16947</link><guid isPermaLink="true">https://community.m5stack.com/post/16947</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 17 Mar 2022 17:05:32 GMT</pubDate></item><item><title><![CDATA[Reply to Mis-match between M5stack Core2 version and flow.m5stack.com on Thu, 17 Mar 2022 15:28:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>  The instructions you gave, to change the Version to Beta, only apply to the web app, but then you say the web app is out of date. Therefore it's unclear whether I should be using the desktop or web UI.  Thanks.  Note: I just found that I can use <a href="http://flow.m5stack.com" target="_blank" rel="noopener noreferrer nofollow ugc">flow.m5stack.com</a> UI, it shows 1.9.3 version upper left, which matches my device version.  I can't figure out how to get the desktop software to 1.9.3.  Oh well.</p>
]]></description><link>https://community.m5stack.com/post/16945</link><guid isPermaLink="true">https://community.m5stack.com/post/16945</guid><dc:creator><![CDATA[david-bethesda]]></dc:creator><pubDate>Thu, 17 Mar 2022 15:28:51 GMT</pubDate></item><item><title><![CDATA[Reply to Mis-match between M5stack Core2 version and flow.m5stack.com on Thu, 17 Mar 2022 17:52:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/david-bethesda" aria-label="Profile: david-bethesda">@<bdi>david-bethesda</bdi></a> web as desktop app is out of date</p>
]]></description><link>https://community.m5stack.com/post/16942</link><guid isPermaLink="true">https://community.m5stack.com/post/16942</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 17 Mar 2022 17:52:02 GMT</pubDate></item><item><title><![CDATA[Reply to Mis-match between M5stack Core2 version and flow.m5stack.com on Thu, 17 Mar 2022 10:53:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks!  So should we be using the web-based UIFlow, or the desktop client?</p>
<p dir="auto">I am having great trouble finding organized, clear and complete documentation.</p>
]]></description><link>https://community.m5stack.com/post/16939</link><guid isPermaLink="true">https://community.m5stack.com/post/16939</guid><dc:creator><![CDATA[david-bethesda]]></dc:creator><pubDate>Thu, 17 Mar 2022 10:53:14 GMT</pubDate></item><item><title><![CDATA[Reply to Mis-match between M5stack Core2 version and flow.m5stack.com on Wed, 16 Mar 2022 20:40:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/david-bethesda" aria-label="Profile: david-bethesda">@<bdi>david-bethesda</bdi></a> Click on the icon of the 3 horizontal line to open settings, click on VER and change to beta</p>
]]></description><link>https://community.m5stack.com/post/16936</link><guid isPermaLink="true">https://community.m5stack.com/post/16936</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 16 Mar 2022 20:40:13 GMT</pubDate></item></channel></rss>
