<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Help with module HX711 scale kit by M5Stack]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">I purchased a scale with HX711 module with 4 load cells:</p>
<p dir="auto">This -&gt; <a href="https://shop.m5stack.com/products/scale-kit-with-weight-unit?_pos=1&amp;_sid=2f18505d1&amp;_ss=r" target="_blank" rel="noopener noreferrer nofollow ugc">SCALE KIT WITH WEIGHT UNIT</a></p>
<p dir="auto">The circuit is very simple to connect. I'm using ESP32, clock and data pins are on pins 18 and 5 and power is on GND and VIN.</p>
<p dir="auto">But I'm only using 1 of the load cells because it came closest to the values ​​while I was testing. Is this possible and is it correct with this kit?</p>
<p dir="auto">I found <a href="https://github.com/m5stack/M5Stack/blob/master/examples/Unit/WEIGHT_HX711/WEIGHT_HX711.ino" target="_blank" rel="noopener noreferrer nofollow ugc">the following code</a> on M5Stack's GitHub, but it also gives me completely unrealistic values, I put 1kg on the scale and it gives me "-45g, -47g".</p>
<p dir="auto">The library examples don't help me much because it doesn't have calibration examples and then it returns unrealistic values.</p>
<p dir="auto">Does anyone have experience with this module and scale? Could you give me some better guidance to configure the use of the scale?</p>
<p dir="auto">Thank you very much.</p>
]]></description><link>https://community.m5stack.com/topic/4132/help-with-module-hx711-scale-kit-by-m5stack</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 12:01:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4132.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 Mar 2022 20:52:09 GMT</pubDate><ttl>60</ttl></channel></rss>
