<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Failed to use CAN with M5Stack]]></title><description><![CDATA[<p dir="auto">返信: <a href="/topic/115/m5stack-with-can">M5Stack with CAN</a><br />
I tried the follow library, changed pin to GPIO17/16<br />
<a href="https://github.com/nhatuan84/arduino-esp32-can-demo" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/nhatuan84/arduino-esp32-can-demo</a></p>
<p dir="auto">But it does not work. I used oscilloscope to check the output from pin GPIO 17/16, There is no any output.<br />
Could someone give me an example code that works, and a picture of connection.<br />
Thanks!</p>
]]></description><link>https://community.m5stack.com/topic/415/failed-to-use-can-with-m5stack</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 05:18:29 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/415.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Nov 2018 08:48:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Failed to use CAN with M5Stack on Wed, 02 Jan 2019 05:07:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayashi" aria-label="Profile: hayashi">@<bdi>hayashi</bdi></a><br />
Hey, here's the example about CAN.<br />
<a href="https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Module/COMMU/Arduino/CAN" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Module/COMMU/Arduino/CAN</a></p>
]]></description><link>https://community.m5stack.com/post/2297</link><guid isPermaLink="true">https://community.m5stack.com/post/2297</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Wed, 02 Jan 2019 05:07:03 GMT</pubDate></item><item><title><![CDATA[Reply to Failed to use CAN with M5Stack on Mon, 26 Nov 2018 07:06:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a><br />
Thank you, please inform me if you upload that sample codes.<br />
I have another question, why there is a CAN controller MCP2515 on the extend module? Does not M5STACK include CAN controller?</p>
]]></description><link>https://community.m5stack.com/post/2086</link><guid isPermaLink="true">https://community.m5stack.com/post/2086</guid><dc:creator><![CDATA[Hayashi]]></dc:creator><pubDate>Mon, 26 Nov 2018 07:06:11 GMT</pubDate></item><item><title><![CDATA[Reply to Failed to use CAN with M5Stack on Mon, 26 Nov 2018 02:26:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayashi" aria-label="Profile: hayashi">@<bdi>hayashi</bdi></a><br />
I have some test program about this<code>COMMU</code> module. Recently, I'll add those example codes to m5stack's documentation.</p>
]]></description><link>https://community.m5stack.com/post/2082</link><guid isPermaLink="true">https://community.m5stack.com/post/2082</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Mon, 26 Nov 2018 02:26:23 GMT</pubDate></item><item><title><![CDATA[Reply to Failed to use CAN with M5Stack on Mon, 26 Nov 2018 02:11:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/watson" aria-label="Profile: watson">@<bdi>watson</bdi></a><br />
I didnot use any extend module, only connect M5Stack to a CAN-tranceiver. Also I am going to buy that module. Could you tell me how to use that module?</p>
]]></description><link>https://community.m5stack.com/post/2080</link><guid isPermaLink="true">https://community.m5stack.com/post/2080</guid><dc:creator><![CDATA[Hayashi]]></dc:creator><pubDate>Mon, 26 Nov 2018 02:11:43 GMT</pubDate></item><item><title><![CDATA[Reply to Failed to use CAN with M5Stack on Fri, 23 Nov 2018 07:24:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hayashi" aria-label="Profile: hayashi">@<bdi>hayashi</bdi></a><br />
Hi hayashi</p>
<p dir="auto">I want to confirm which module you used?<br />
Is that one?<br />
<a href="https://www.aliexpress.com/store/product/M5Stack-New-COMMU-Module-Extend-RS485-TTL-CAN-I2C-Port-with-MCP2515-TJA1051-SP3485-Development-Board/3226069_32954475633.html?spm=a2g1y.12024536.productList_5885011.subject_1" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.aliexpress.com/store/product/M5Stack-New-COMMU-Module-Extend-RS485-TTL-CAN-I2C-Port-with-MCP2515-TJA1051-SP3485-Development-Board/3226069_32954475633.html?spm=a2g1y.12024536.productList_5885011.subject_1</a></p>
]]></description><link>https://community.m5stack.com/post/2062</link><guid isPermaLink="true">https://community.m5stack.com/post/2062</guid><dc:creator><![CDATA[m5-docs]]></dc:creator><pubDate>Fri, 23 Nov 2018 07:24:55 GMT</pubDate></item></channel></rss>
