<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PB unit lorawan 868 error received data= &quot;Ag==&quot;]]></title><description><![CDATA[<p dir="auto">hello, I have a lorawan module "unit lorawan 868" connected to a "m5stack core2" all this must communicate locally with a multitech gateway<br />
AEP that I bought and configured then I retrieve the data in "mqtt" by cable from the gateway.<br />
I manage to get my lorawan unit 868 module to communicate to the gateway. I have the messages that the join is going well, the sending with the command "AT+DTRX=1,2,10,0123456789" done well, I have the return of the order with the sending, sent and received: return command-&gt;<br />
"OK+SEND:05<br />
[ INFO ] SEND NUM 05<br />
AT+CSTATUS?<br />
+CSTATUS:00<br />
OK<br />
OK+SENT:01<br />
[ INFO ] SEND CNT 01<br />
+CLINKCHECK: 0, 22, 1, -13, 10<br />
(1/2), 1, -13, 10<br />
OK+RECV:04,00,00"<br />
In my mqtt server and on the gateway, I can clearly see the join happening and the dtrx also so I subscribed with a python server to the topic "lora/.../up" and the data which is supposed to correspond to what I send decode in base 64 does not correspond at all to what I send. I always have "data: Ag==", it is only when I increase the size of the message that it changes a little but it's like the data was corrupted...<br />
If you have the solution, I'm a taker</p>
]]></description><link>https://community.m5stack.com/topic/4150/pb-unit-lorawan-868-error-received-data-ag</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 14:20:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4150.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 24 Mar 2022 11:24:02 GMT</pubDate><ttl>60</ttl></channel></rss>
