<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[BLE with the arduino framework]]></title><description><![CDATA[<p dir="auto">We are using the M5core2 and we want to run a BLE-based application using the Arduino programming framework. We download the library for the ESP architecture: <a href="https://www.arduino.cc/reference/en/libraries/esp32-ble-arduino/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.arduino.cc/reference/en/libraries/esp32-ble-arduino/</a></p>
<p dir="auto">But, it seems that the library is not compatible with this architecture. We got the following error when initializing the library.</p>
<p dir="auto">***Guru Meditation Error: Core  1 panic'ed (Interrupt wdt timeout on CPU1)<br />
Core 1 register dump:<br />
PC      : 0x40096769  PS      : 0x00060334  A0      : 0x800987a2  A1      : 0x3ffc8080<br />
A2      : 0x37735134  A3      : 0x0000abab  A4      : 0xb33fffff  A5      : 0x00000001<br />
A6      : 0x00060120  A7      : 0x0000cdcd  A8      : 0x400df228  A9      : 0x3ffc81a0<br />
A10     : 0x3f41ef14  A11     : 0x00000069  A12     : 0x3f41f248  A13     : 0x3f41efa0<br />
A14     : 0x00000001  A15     : 0x00000000  SAR     : 0x00000020  EXCCAUSE: 0x00000006<br />
EXCVADDR: 0x00000000  LBEG    : 0x40092a50  LEND    : 0x40092a6c  LCOUNT  : 0xffffffff</p>
<p dir="auto">ELF file SHA256: 0000000000000000</p>
<p dir="auto">Backtrace: 0x40096769:0x3ffc8080 0x4009879f:0x3ffc80b0 0x40098dc9:0x3ffc80d0 0x4008239d:0x3ffc80f0 0x400825d4:0x3ffc8110 0x40082639:0x3ffc8130 0x400f1a6d:0x3ffc8180 0x400f1065:0x3ffc81a0 0x400d66a2:0x3ffc81d0 0x400d1825:0x3ffc8200 0x400dd3e2:0x3ffc8250 0x40095736:0x3ffc8270</p>
<p dir="auto">Core 0 register dump:<br />
PC      : 0x40015c45  PS      : 0x00060434  A0      : 0x80015e4d  A1      : 0x3ffcb8d0<br />
A2      : 0x3ffcb9e0  A3      : 0x3ffcb940  A4      : 0x4efc3e53  A5      : 0x00000008<br />
A6      : 0x3ffcb940  A7      : 0x3ffcb9e0  A8      : 0x3ffcb9fc  A9      : 0x00000007<br />
A10     : 0x6a73bc23  A11     : 0xffffffff  A12     : 0x00000000  A13     : 0x6a73bc23<br />
A14     : 0x00060220  A15     : 0x00000000  SAR     : 0x0000001f  EXCCAUSE: 0x00000006<br />
EXCVADDR: 0x00000000  LBEG    : 0x4000c46c  LEND    : 0x4000c477  LCOUNT  : 0x00000000</p>
<p dir="auto">Backtrace: 0x40015c45:0x3ffcb8d0 0x40015e4a:0x3ffcb8f0 0x4001606a:0x3ffcb940 0x400161b9:0x3ffcb990 0x400162a1:0x3ffcba30 0x40016889:0x3ffcbc40 0x40016c1a:0x3ffcbd70 0x40019d11:0x3ffcbdf0 0x40055b4d:0x3ffcbe10 0x4016abbf:0x3ffcbe30 0x4016b1cd:0x3ffcbe50 0x40095736:0x3ffcbe80</p>
<p dir="auto">Rebooting...***</p>
<p dir="auto">Does the M5core 2 support the BLE communication? Is there any Arduino-based library to handle the communication?</p>
<p dir="auto">We have tested the library with the M5stack core hardware and it run properly.</p>
]]></description><link>https://community.m5stack.com/topic/4167/ble-with-the-arduino-framework</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 13:47:13 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4167.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Mar 2022 15:23:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to BLE with the arduino framework on Mon, 06 Jun 2022 04:36:24 GMT]]></title><description><![CDATA[<p dir="auto">Hello. Not sure if you managed to get this working yet, but if not, there is a ble library that ships with M5Stack Core2 Arduino install.</p>
<p dir="auto">#include &lt;BLEDevice.h&gt;<br />
on my computer this was installed at this location: .//Library/Arduino15/packages/m5stack/hardware/esp32/2.0.3/libraries/BLE/src/BLEDevice.h<br />
Hence I did not have to install the package separately.<br />
I have implemented a project using this just recently using a variety of BLE technology so confident that it works on at least my copy of Core2.</p>
<p dir="auto">If you go to the docs link from the library link you posted (<a href="https://github.com/nkolban/ESP32_BLE_Arduino" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/nkolban/ESP32_BLE_Arduino</a>) you can see that the project has now been directly incorporated into Arduino. The lib version you may have downloaded may be out of date. You can find BLEDevice.h/BLEDevice.cpp on your machine and check against the main Arduino source.</p>
<p dir="auto">Hope this helps?</p>
]]></description><link>https://community.m5stack.com/post/17658</link><guid isPermaLink="true">https://community.m5stack.com/post/17658</guid><dc:creator><![CDATA[decidable]]></dc:creator><pubDate>Mon, 06 Jun 2022 04:36:24 GMT</pubDate></item></channel></rss>
