<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Core 2 appears to be bricked]]></title><description><![CDATA[<p dir="auto">No response ( no display or sound)  upon plugging in usb power.  Was working fine until I tried uploading a sketch.  Burn fails.   I <em><strong>am</strong></em> getting a response to ls:</p>
<p dir="auto">ls /dev/tty.wch*<br />
/dev/tty.wchusbserial537E0144481</p>
<p dir="auto">File "/Applications/M5Burner.app/Contents/Resources/packages/tools/serial/serialposix.py", line 268, in open<br />
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))<br />
serial.serialutil.SerialException: [Errno 16] could not open port /dev/tty.wchusbserial537E0144481: [Errno 16] Resource busy: '/dev/tty.wchusbserial537E0144481'</p>
<p dir="auto">Any suggestions?</p>
]]></description><link>https://community.m5stack.com/topic/4176/m5stack-core-2-appears-to-be-bricked</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:06:04 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4176.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 Apr 2022 15:07:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Core 2 appears to be bricked on Mon, 04 Apr 2022 12:58:08 GMT]]></title><description><![CDATA[<p dir="auto">I was finally able to Erase and get things back to normal.</p>
]]></description><link>https://community.m5stack.com/post/17087</link><guid isPermaLink="true">https://community.m5stack.com/post/17087</guid><dc:creator><![CDATA[david-bethesda]]></dc:creator><pubDate>Mon, 04 Apr 2022 12:58:08 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core 2 appears to be bricked on Mon, 04 Apr 2022 12:51:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/david-bethesda" aria-label="Profile: david-bethesda">@<bdi>david-bethesda</bdi></a> programs can randomly block the port using m5burner sometimes resets the port (or something else strange ) and allows the boot loader to be over written resetting the device.</p>
]]></description><link>https://community.m5stack.com/post/17086</link><guid isPermaLink="true">https://community.m5stack.com/post/17086</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 04 Apr 2022 12:51:10 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core 2 appears to be bricked on Mon, 04 Apr 2022 12:45:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks.  I referenced my attempt with Burner in the original post.  I tried a subsequent time and it finally worked.  So I think I'm good now.  It's not clear to me how Burner could ever work if a program is attached to the serial port -- does Burner not require the serial port itself?</p>
]]></description><link>https://community.m5stack.com/post/17084</link><guid isPermaLink="true">https://community.m5stack.com/post/17084</guid><dc:creator><![CDATA[david-bethesda]]></dc:creator><pubDate>Mon, 04 Apr 2022 12:45:18 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core 2 appears to be bricked on Mon, 04 Apr 2022 04:54:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/david-bethesda" aria-label="Profile: david-bethesda">@<bdi>david-bethesda</bdi></a> no, there is no button press to factory reset.</p>
<p dir="auto">if you download and install m5burner which is an application used to flash firmwares to the core2.</p>
<p dir="auto">In the top right corner of the application in an "erase" button (you may need to resize the window) you can use this to remove any code running in the core2's memory.</p>
]]></description><link>https://community.m5stack.com/post/17082</link><guid isPermaLink="true">https://community.m5stack.com/post/17082</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Mon, 04 Apr 2022 04:54:27 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core 2 appears to be bricked on Sun, 03 Apr 2022 18:09:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a>  thanks but when you say “wipe” using Burner which operation are you talking about?  In my post I show the output from an attempt to use M5Burner. I agree with your theory that The unit is running my sketch which is either holding up the serial connection or doing something similar. What I don’t understand about this unit is the apparent lack of a factory reset using the buttons somehow and starting from scratch with a boot strap or something similar. Is there no such function?</p>
]]></description><link>https://community.m5stack.com/post/17079</link><guid isPermaLink="true">https://community.m5stack.com/post/17079</guid><dc:creator><![CDATA[david-bethesda]]></dc:creator><pubDate>Sun, 03 Apr 2022 18:09:22 GMT</pubDate></item><item><title><![CDATA[Reply to M5Stack Core 2 appears to be bricked on Sun, 03 Apr 2022 16:28:54 GMT]]></title><description><![CDATA[<p dir="auto">You probably uploaded a sketch which is blocking the port.<br />
Try using M5Burner to wipe the Core2</p>
]]></description><link>https://community.m5stack.com/post/17078</link><guid isPermaLink="true">https://community.m5stack.com/post/17078</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sun, 03 Apr 2022 16:28:54 GMT</pubDate></item></channel></rss>
