<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5stack Fire setup issues]]></title><description><![CDATA[<p dir="auto">Hi<br />
Just got an m5stack fire and was able to connct him to wifi.<br />
Now a barcode is shown and if a ifollow that link i end on the <a href="http://m5go.com" target="_blank" rel="noopener noreferrer nofollow ugc">m5go.com</a> webpage.<br />
But on that webpage my fire is lways shown as offline:</p>
<p dir="auto">ID ( xxxx ) : Offline</p>
<p dir="auto">I do not have a firewall or something special.</p>
<p dir="auto">The Serial output looks ok:</p>
<pre><code>ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4848
ho 0 tail 12 room 4
load:0x40078000,len:7436
load:0x40080000,len:7076
entry 0x40080348
Internal FS (SPIFFS): Mounted on partition 'internalfs' [size: 2490368; Flash address: 0x1A0000]
Filesystem size: 2281728 B
           Used: 932864 B
           Free: 1348864 B
Device ID:840d8e258d00
LCD initializing...Done!
[6962] State change: STA_STARTUP ===&gt; STA_GUIDE
[14533] State change: STA_GUIDE ===&gt; STA_CONNECT_WIFI
....[WiFi] event: 4 (Station connected to AP)
        info: {'ssid': 'uhu-privat', 'channel': 1}
.....Connected!
[16615] State change: STA_CONNECT_WIFI ===&gt; STA_WEB_QRCODE
[WiFi] event: 7 (Station got IP from connected AP)
        info: {'ip': '10.1.1.117', 'changed': True}
MicroPython ESP32_LoBo_v3.2.20 - 2018-06-28 on M5Stack with ESP32
&gt;&gt;&gt; [M5-xxxxyyyyyyyyyyy] M5Cloud connected.
<p dir="auto">any idea whats wrong or where i can get support?</p>
<p dir="auto">thanks<br />
andi</p>
]]></description><link>https://community.m5stack.com/topic/418/m5stack-fire-setup-issues</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 06:17:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/418.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Nov 2018 18:48:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5stack Fire setup issues on Tue, 27 Nov 2018 02:01:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi roadfox,</p>
<p dir="auto">The coding platforms you can connect to (m5go, m5cloud, ui flow) depend on what firmware you have burned<br />
on your device. For example if you have m5go firmware you cannot connect to the ui flow site with it.</p>
<p dir="auto">The firmware can be easily changed/re-flashed by using the burner tools on our website<br />
for windows <a href="http://flow.m5stack.com/download/M5Burner-flow-only.zip" target="_blank" rel="noopener noreferrer nofollow ugc">http://flow.m5stack.com/download/M5Burner-flow-only.zip</a><br />
for mac <a href="http://flow.m5stack.com/download/M5Burner_MacOS.zip" target="_blank" rel="noopener noreferrer nofollow ugc">http://flow.m5stack.com/download/M5Burner_MacOS.zip</a></p>
<p dir="auto">You can follow this youtube guide on how to flash your device if you get stuck<br />
<a href="https://www.youtube.com/watch?v=oEiFLsukAEE" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.youtube.com/watch?v=oEiFLsukAEE</a></p>
<p dir="auto">Hope this helps, let us know if you manage to get setup</p>
]]></description><link>https://community.m5stack.com/post/2087</link><guid isPermaLink="true">https://community.m5stack.com/post/2087</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Tue, 27 Nov 2018 02:01:28 GMT</pubDate></item></channel></rss>
