<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Antenna Rotor Control]]></title><description><![CDATA[<p dir="auto">Hello everybody,<br />
I am approaching this interesting system today.<br />
I would like to make a small portable antenna rotor that I can control with M5stack.<br />
I need to be able to visualize the position in order to calculate the degrees and insert keys to make it rotate in both directions from -15 ° to 360 + 15 °<br />
I am wondering what kind of motor to use also to be able to adjust the rotation speed around 1RPM.<br />
Also if you have two tips on how to set up the logic.<br />
Thank you</p>
]]></description><link>https://community.m5stack.com/topic/4193/antenna-rotor-control</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 14:47:28 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4193.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Apr 2022 06:51:41 GMT</pubDate><ttl>60</ttl></channel></rss>
