<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[multiple 4-Relays on same I2C bus]]></title><description><![CDATA[<p dir="auto">Is there a way to control more then 1 4-relay units with a StickC+ ?</p>
]]></description><link>https://community.m5stack.com/topic/4198/multiple-4-relays-on-same-i2c-bus</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 15:05:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4198.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Apr 2022 23:59:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to multiple 4-Relays on same I2C bus on Sat, 09 Apr 2022 20:08:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bartblommaerts" aria-label="Profile: bartblommaerts">@<bdi>bartblommaerts</bdi></a> said in <a href="/post/17145">multiple 4-Relays on same I2C bus</a>:</p>
<p dir="auto">Oh the PaHub&gt;2&lt; Unit :/</p>
<p dir="auto">its not available yet in the local stores. And the Pa.Hub (version 1) is sold out.</p>
<p dir="auto">You're better off ordering direct from M5Stack</p>
]]></description><link>https://community.m5stack.com/post/17147</link><guid isPermaLink="true">https://community.m5stack.com/post/17147</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 09 Apr 2022 20:08:49 GMT</pubDate></item><item><title><![CDATA[Reply to multiple 4-Relays on same I2C bus on Sat, 09 Apr 2022 13:23:54 GMT]]></title><description><![CDATA[<p dir="auto">Oh the PaHub&gt;2&lt; Unit :/</p>
]]></description><link>https://community.m5stack.com/post/17145</link><guid isPermaLink="true">https://community.m5stack.com/post/17145</guid><dc:creator><![CDATA[bartblommaerts]]></dc:creator><pubDate>Sat, 09 Apr 2022 13:23:54 GMT</pubDate></item><item><title><![CDATA[Reply to multiple 4-Relays on same I2C bus on Sat, 09 Apr 2022 11:52:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> said in <a href="/post/17143">multiple 4-Relays on same I2C bus</a>:</p>
<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/bartblommaerts" aria-label="Profile: bartblommaerts">@<bdi>bartblommaerts</bdi></a></p>
<p dir="auto">from what I can tell the 4-relay unit has a fixed I2C address (0x26) so connecting more than one directly doesn't work (I2C address conflict).</p>
<p dir="auto">However you should be able to control multiple 4-Relay units through a <a href="https://docs.m5stack.com/en/unit/pahub2" target="_blank" rel="noopener noreferrer nofollow ugc">PaHub2</a>.</p>
<p dir="auto">Note: I do not have the necessary units to test whether it actually works or not. My conclusion is solely from looking at the documentation.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> is correct. The Address is hard coded and so you need to use the I2C hub for more that 1 unit.</p>
]]></description><link>https://community.m5stack.com/post/17144</link><guid isPermaLink="true">https://community.m5stack.com/post/17144</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Sat, 09 Apr 2022 11:52:02 GMT</pubDate></item><item><title><![CDATA[Reply to multiple 4-Relays on same I2C bus on Sat, 09 Apr 2022 10:43:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/bartblommaerts" aria-label="Profile: bartblommaerts">@<bdi>bartblommaerts</bdi></a></p>
]]></description><link>https://community.m5stack.com/post/17143</link><guid isPermaLink="true">https://community.m5stack.com/post/17143</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 09 Apr 2022 10:43:19 GMT</pubDate></item></channel></rss>
