<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with Lists over ESP-now in Blocky]]></title><description><![CDATA[<p dir="auto">Hello all.</p>
<p dir="auto">i don't know it is a bug or it is my mistake.</p>
<p dir="auto">On a single m5 controller i create a list with multible entrys.<br />
Exempel for ENV 3 Unit can i use a generate a list with 3 records for each sensor.<br />
When i using a label on this list the display show me [24.4334, 43.4765, 95340]</p>
<p dir="auto">Now i take this list and use the in Blocky <em>List &gt; in List [variableswithlist] get # [1]</em> and so on, can i show for each record a single value on display correctly. Wonderfull.</p>
<p dir="auto">So i take a other M5-controller with the exemple ENV III Unit and creathe exact the same list and i send it over ESP-NOW or UART to another M5-Controller and the reciver show me the same string on display [24.4334, 43.4765, 95340] and i want to split this for every with <em>List &gt; in List [variableswithlist] get # [1]</em> label show a single value doesn't work.</p>
<p dir="auto">On Display show me only a first single charakter if <em>get # [1]</em> in label for example [ for ESP-NOW<br />
Or wenn i using UART show two charakter and the position is not apparent.</p>
<p dir="auto">Ok, i found a alternative. I can use <em>List &gt; in List [variableswithlist] get sub-list from # [1] to # [5]</em><br />
This is ok if list length stable, but if this dynamic is this feathure useless</p>
<p dir="auto">I've been playing for 6 hours today trying to solve this problem with no success.</p>
<p dir="auto">My goal is i place three or four M5StickC with YUN Hat for watching Temperatur, Humity and Pressure and send this information over EPS-Now to my M5Core2 and show me all M5StickC Devices at Display and store the Data to SD-Card.</p>
<p dir="auto">I hope someone can help me there. Thanks</p>
<p dir="auto">Best regards.</p>
]]></description><link>https://community.m5stack.com/topic/4212/problem-with-lists-over-esp-now-in-blocky</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:49:36 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4212.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Apr 2022 14:48:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with Lists over ESP-now in Blocky on Tue, 25 Mar 2025 21:35:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nabstar" aria-label="Profile: nabstar">@<bdi>nabstar</bdi></a> Did you ever find a solution for this? I’m having a similar problem</p>
]]></description><link>https://community.m5stack.com/post/28653</link><guid isPermaLink="true">https://community.m5stack.com/post/28653</guid><dc:creator><![CDATA[Boomvalt]]></dc:creator><pubDate>Tue, 25 Mar 2025 21:35:46 GMT</pubDate></item></channel></rss>
