<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved]M5Stack Fire Microphone?]]></title><description><![CDATA[<p dir="auto">Does the M5Stack Fire have a microphone?<br />
The advertising says it does.<br />
There are internet references to a MEMS BSE3729 mic on GPIO 35. But the I can’t get the Arduino mic example to work. I looked inside and I saw D1 at the enclosure mic hole which which seems to have a different purpose. I can’t find a mic on the schematic but I could have the wrong schematic or don’t know what the mic symbol looks like.<br />
I searched this forum and found a mic+leds+FFT example but that didn’t work either.</p>
<p dir="auto">Could someone provide a link to a schematic with a mic on it and give the ref designation to help me find it on the M5Stack Fire circuit board. If I can find it, I can get it to work.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/423/solved-m5stack-fire-microphone</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 20:20:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/423.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Nov 2018 14:38:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved]M5Stack Fire Microphone? on Thu, 29 Nov 2018 13:52:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lukasmaximus" aria-label="Profile: lukasmaximus">@<bdi>lukasmaximus</bdi></a><br />
Thank you. Will try pin 34.</p>
]]></description><link>https://community.m5stack.com/post/2105</link><guid isPermaLink="true">https://community.m5stack.com/post/2105</guid><dc:creator><![CDATA[bobolink]]></dc:creator><pubDate>Thu, 29 Nov 2018 13:52:34 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved]M5Stack Fire Microphone? on Thu, 29 Nov 2018 09:11:19 GMT]]></title><description><![CDATA[<p dir="auto">Hi bobolink according to the github documentation page<br />
<a href="https://m5stack.github.io/m5-docs/#/en/product_documents/m5stack-core/m5core_fire" target="_blank" rel="noopener noreferrer nofollow ugc">https://m5stack.github.io/m5-docs/#/en/product_documents/m5stack-core/m5core_fire</a></p>
<p dir="auto">The microphone is located on pin 34</p>
<p dir="auto">I tested the vu meter in the Fire examples<br />
<a href="https://github.com/m5stack/M5Stack/tree/master/examples/Fire/M5StackFire_NeoPixelVUmeter" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/m5stack/M5Stack/tree/master/examples/Fire/M5StackFire_NeoPixelVUmeter</a></p>
<p dir="auto">and it worked fine, could you please test again using pin 34<br />
and see whether it works, if not it could be a faulty microphone</p>
]]></description><link>https://community.m5stack.com/post/2103</link><guid isPermaLink="true">https://community.m5stack.com/post/2103</guid><dc:creator><![CDATA[lukasmaximus]]></dc:creator><pubDate>Thu, 29 Nov 2018 09:11:19 GMT</pubDate></item></channel></rss>
