<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[DC Brush Motor Control]]></title><description><![CDATA[<p dir="auto">I have been using an Arduino based dc motor controller for my model railway locomotives. The modules use Wi-Fi and are controlled using my mobile phone.<br />
Unfortunately the supplier has stopped manufacturing them.<br />
Looking online I came across the M5Stack Atom PWM kit, which appears to be able to control a brushed screen motor using Wi-Fi.<br />
However, searching through the GitHub, I couldn’t find any documentation on how to build/programme the module or connect to a mobile phone.<br />
Is this particular module capable of being used to control a dc motor using a mobile phone (in particular an iPhone)?<br />
I am not a programmer which is why I used to purchase ready made modules that were pre-programmed.</p>
]]></description><link>https://community.m5stack.com/topic/4245/dc-brush-motor-control</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 20:37:02 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4245.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 26 Apr 2022 14:27:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to DC Brush Motor Control on Wed, 27 Apr 2022 05:03:34 GMT]]></title><description><![CDATA[<p dir="auto">If you use UIFLow you can make a loco controlled via a mobil phone easy however, the PWM lacks a H-Bridge and so will only work in one direction.</p>
<p dir="auto">I have started a model railway series using M5Stack controllers here: <a href="https://www.hackster.io/AJB2K3/m5stack-model-railway-part-1-b109f7" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.hackster.io/AJB2K3/m5stack-model-railway-part-1-b109f7</a></p>
]]></description><link>https://community.m5stack.com/post/17307</link><guid isPermaLink="true">https://community.m5stack.com/post/17307</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 27 Apr 2022 05:03:34 GMT</pubDate></item></channel></rss>
