<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Core2 no MQTT on download]]></title><description><![CDATA[<p dir="auto">This has been published before, but it is really both obvious and a major bug. Simple to describe: MQTT never connects or works after you burned your software to the M5Core2</p>
]]></description><link>https://community.m5stack.com/topic/4252/m5core2-no-mqtt-on-download</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 01:00:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4252.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Apr 2022 09:04:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Core2 no MQTT on download on Mon, 02 May 2022 10:19:06 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/simmoe" aria-label="Profile: simmoe">@<bdi>simmoe</bdi></a></p>
<p dir="auto">I don't know why it does work with your other products, sorry. I think the UiFlow examples are made for quick testing functionality, e.g. via using <code>Run</code> option, which uses the already existing WiFi connection. But yes, I agree, it probably would make sense to include them in the examples.</p>
]]></description><link>https://community.m5stack.com/post/17366</link><guid isPermaLink="true">https://community.m5stack.com/post/17366</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 02 May 2022 10:19:06 GMT</pubDate></item><item><title><![CDATA[Reply to M5Core2 no MQTT on download on Mon, 02 May 2022 07:20:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a></p>
<p dir="auto">You're right. Tnx. But why does my other products work WITHOUT the wifi-connection block? Have burned a variety of M5sticks/Atoms without having to use the block. If it's mandatory, why not use it in the UIFLOW examples?</p>
]]></description><link>https://community.m5stack.com/post/17364</link><guid isPermaLink="true">https://community.m5stack.com/post/17364</guid><dc:creator><![CDATA[simmoe]]></dc:creator><pubDate>Mon, 02 May 2022 07:20:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5Core2 no MQTT on download on Fri, 29 Apr 2022 16:10:03 GMT]]></title><description><![CDATA[<p dir="auto">Not sure what you are trying to say.<br />
I have literally wrote a book on the subject and MQTT works fine.<br />
We need more information on your issue.</p>
]]></description><link>https://community.m5stack.com/post/17333</link><guid isPermaLink="true">https://community.m5stack.com/post/17333</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 29 Apr 2022 16:10:03 GMT</pubDate></item><item><title><![CDATA[Reply to M5Core2 no MQTT on download on Fri, 29 Apr 2022 10:30:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/simmoe" aria-label="Profile: simmoe">@<bdi>simmoe</bdi></a></p>
<p dir="auto">not sure why you are writing that. Anyways, if your UIFlow code requires a WiFi connection and you want it to work after burning/downloading the UIFlow code, you'll need to make sure WiFi gets connected first. Try to add something like the first two statements I described in this <a href="https://community.m5stack.com/topic/3848/m5paper-deepsleep-with-uiflow/2">post</a>.</p>
]]></description><link>https://community.m5stack.com/post/17330</link><guid isPermaLink="true">https://community.m5stack.com/post/17330</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 29 Apr 2022 10:30:04 GMT</pubDate></item></channel></rss>
