<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cannot use UIFlow with Atom Lite]]></title><description><![CDATA[<p dir="auto">I used M5Burner to write UIFlow_Lite v1.9.6 for the ATOM Lite to my device. It has sucessfully connected to my WiFi, and I have provided the API key on UIFlow.</p>
<p dir="auto">When clicking Run in UIFlow, it connects to the device, and the COM Monitor on the device spits this out:</p>
  File "flow/m5cloud.py", line 105, in _exec_data
  File "&lt;string&gt;", line 8, in &lt;module&gt;
NameError: name '__VERSION__' isn't defined
<p dir="auto">I have tried different versions of the firmware but they all produce this result. I have only just got my device, so I haven't got UIFlow to work at all yet.</p>
]]></description><link>https://community.m5stack.com/topic/4257/cannot-use-uiflow-with-atom-lite</link><generator>RSS for Node</generator><lastBuildDate>Tue, 05 May 2026 01:24:10 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4257.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Apr 2022 11:35:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Sat, 07 May 2022 21:03:07 GMT]]></title><description><![CDATA[<p dir="auto">It appears this bug is fixed, not in the firmware, but in the latest version of UIFlow!</p>
]]></description><link>https://community.m5stack.com/post/17442</link><guid isPermaLink="true">https://community.m5stack.com/post/17442</guid><dc:creator><![CDATA[ahorner]]></dc:creator><pubDate>Sat, 07 May 2022 21:03:07 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Fri, 06 May 2022 22:29:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahorner" aria-label="Profile: ahorner">@<bdi>ahorner</bdi></a> thanks for letting know!</p>
]]></description><link>https://community.m5stack.com/post/17435</link><guid isPermaLink="true">https://community.m5stack.com/post/17435</guid><dc:creator><![CDATA[slavs]]></dc:creator><pubDate>Fri, 06 May 2022 22:29:02 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Fri, 06 May 2022 19:17:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slavs" aria-label="Profile: slavs">@<bdi>slavs</bdi></a> Hi there, to you and to everyone:</p>
<p dir="auto">I contacted M5Stack support and have received a reply. This issue is a known firmware bug with the ATOM Lite.</p>
<p dir="auto">They said:</p>
<p dir="auto">Hi Alex,<br />
Yes. We confirmed that's a bug. We will fix it in recently version.<br />
Currently now, you can click 'reflash' button before downloading the firmware, which should work.<br />
<img src="/assets/uploads/files/1651864640893-catch-resized.jpg" alt="0_1651864638737_Catch.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/17434</link><guid isPermaLink="true">https://community.m5stack.com/post/17434</guid><dc:creator><![CDATA[ahorner]]></dc:creator><pubDate>Fri, 06 May 2022 19:17:43 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Fri, 06 May 2022 18:35:17 GMT]]></title><description><![CDATA[<p dir="auto">I've been experiencing a similar issue with two recently purchased ATOM Lite devices. However I couldn't even connect at all with UI flow on version 1.9.5.</p>
<p dir="auto">I've been using the vscode extension as I find it to work butter than using UI Flow Desktop and Web. But still need to flash the device constantly.</p>
<p dir="auto">Although I can successfully download and run the code, I can't get it to run in App mode, I suspect the OP might have the same problem.</p>
]]></description><link>https://community.m5stack.com/post/17433</link><guid isPermaLink="true">https://community.m5stack.com/post/17433</guid><dc:creator><![CDATA[slavs]]></dc:creator><pubDate>Fri, 06 May 2022 18:35:17 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Thu, 05 May 2022 16:13:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wsanders" aria-label="Profile: wsanders">@<bdi>wsanders</bdi></a> Hi there, I am using the latest firmware with the latest UIFlow</p>
]]></description><link>https://community.m5stack.com/post/17418</link><guid isPermaLink="true">https://community.m5stack.com/post/17418</guid><dc:creator><![CDATA[ahorner]]></dc:creator><pubDate>Thu, 05 May 2022 16:13:20 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Tue, 03 May 2022 18:08:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ahorner" aria-label="Profile: ahorner">@<bdi>ahorner</bdi></a> IIRC I received this error on an M5StickC Plus when the firmware version and UIFlow version did not match.</p>
]]></description><link>https://community.m5stack.com/post/17382</link><guid isPermaLink="true">https://community.m5stack.com/post/17382</guid><dc:creator><![CDATA[wsanders]]></dc:creator><pubDate>Tue, 03 May 2022 18:08:21 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Sun, 01 May 2022 19:55:14 GMT]]></title><description><![CDATA[<p dir="auto">Bump on this one, anyone know what might be going on? Thanks!</p>
]]></description><link>https://community.m5stack.com/post/17358</link><guid isPermaLink="true">https://community.m5stack.com/post/17358</guid><dc:creator><![CDATA[ahorner]]></dc:creator><pubDate>Sun, 01 May 2022 19:55:14 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Sat, 30 Apr 2022 15:02:34 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ahorner" aria-label="Profile: ahorner">@<bdi>ahorner</bdi></a></p>
<p dir="auto">I am sorry to hear. Very strange indeed. Unfortunately I cannot reproduce this issue. Maybe somebody else has an idea about what might be going on?</p>
]]></description><link>https://community.m5stack.com/post/17349</link><guid isPermaLink="true">https://community.m5stack.com/post/17349</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 30 Apr 2022 15:02:34 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Sat, 30 Apr 2022 14:29:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Hi Felix</p>
<p dir="auto">Unfortunately, I am back,</p>
<p dir="auto">It appears if I reset or unplug and plug back in (effective reset) the device, the issue comes back.</p>
<p dir="auto">The device will only work after an erase, burn and connect to UIFlow. Once connected, I can run as much as I like. Any disconnect appears to "kill" the device with the aformentioned python error on the COM Monitor until I do another erase, burn and connect etc,</p>
<p dir="auto">Thanks,</p>
<p dir="auto">Alex</p>
]]></description><link>https://community.m5stack.com/post/17348</link><guid isPermaLink="true">https://community.m5stack.com/post/17348</guid><dc:creator><![CDATA[ahorner]]></dc:creator><pubDate>Sat, 30 Apr 2022 14:29:32 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Sat, 30 Apr 2022 14:06:47 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ahorner" aria-label="Profile: ahorner">@<bdi>ahorner</bdi></a></p>
<p dir="auto">thank you for reporting back. I am glad to hear you've got it working.</p>
]]></description><link>https://community.m5stack.com/post/17347</link><guid isPermaLink="true">https://community.m5stack.com/post/17347</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 30 Apr 2022 14:06:47 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Sat, 30 Apr 2022 13:55:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> Hi Felix,</p>
<p dir="auto">A full erase and reburn, with a change of API key, has corrected the problem. Doh! How did I not already try this?!?!</p>
<p dir="auto">Many thanks,</p>
]]></description><link>https://community.m5stack.com/post/17346</link><guid isPermaLink="true">https://community.m5stack.com/post/17346</guid><dc:creator><![CDATA[ahorner]]></dc:creator><pubDate>Sat, 30 Apr 2022 13:55:38 GMT</pubDate></item><item><title><![CDATA[Reply to Cannot use UIFlow with Atom Lite on Sat, 30 Apr 2022 13:33:47 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ahorner" aria-label="Profile: ahorner">@<bdi>ahorner</bdi></a></p>
<p dir="auto">works for me here. Tried with firmware 1.9.6 and 1.7.5. I do not get this error.</p>
<p dir="auto">Could you share the actual code you tried to run? Have you tried to erase and re-burn the firmware? (Please note: if you do, the API key will change.)</p>
]]></description><link>https://community.m5stack.com/post/17344</link><guid isPermaLink="true">https://community.m5stack.com/post/17344</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sat, 30 Apr 2022 13:33:47 GMT</pubDate></item></channel></rss>
