<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[switches from USB mode to app mode]]></title><description><![CDATA[<p dir="auto">I can successfully load and run examples ONCE in USB or internet mode. Then the M5core2 switches to app mode and I have to return to burner and switch the config back to USB.</p>
<p dir="auto">How to I eliminate this hassle and run several examples in sequence?</p>
<p dir="auto">Still awaiting help on my missing touch on my AWS core2.</p>
<p dir="auto">Bo W4GHV</p>
]]></description><link>https://community.m5stack.com/topic/4258/switches-from-usb-mode-to-app-mode</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 07:13:27 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4258.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 May 2022 15:35:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to switches from USB mode to app mode on Tue, 03 May 2022 18:06:11 GMT]]></title><description><![CDATA[<p dir="auto">Also, if your sketch has any code that uses Wifi, your device will disconnect from UIflow. It will not reconnect when your sketch is finished. To work around this I keep the M5Burner open; when you click on "configure" it will reset the device via USB. Even then, your device will not connect right away, so go down to the lower left corner of the UIFlow window and clock on "Reconnect".</p>
<p dir="auto">"App Mode" and "Download" are most useful when you are done testing your code.</p>
]]></description><link>https://community.m5stack.com/post/17381</link><guid isPermaLink="true">https://community.m5stack.com/post/17381</guid><dc:creator><![CDATA[wsanders]]></dc:creator><pubDate>Tue, 03 May 2022 18:06:11 GMT</pubDate></item><item><title><![CDATA[Reply to switches from USB mode to app mode on Mon, 02 May 2022 02:37:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a>  Thank you VERY MUCH. Now I can have lots of fun/learning (without touch function, which is not working).<br />
Bo</p>
]]></description><link>https://community.m5stack.com/post/17360</link><guid isPermaLink="true">https://community.m5stack.com/post/17360</guid><dc:creator><![CDATA[W4GHV]]></dc:creator><pubDate>Mon, 02 May 2022 02:37:53 GMT</pubDate></item><item><title><![CDATA[Reply to switches from USB mode to app mode on Sun, 01 May 2022 19:45:05 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/w4ghv" aria-label="Profile: W4GHV">@<bdi>W4GHV</bdi></a></p>
<p dir="auto">UiFlow offers two options: <code>Run</code> and <code>Download</code>. What you want is <code>Run</code> - see below explanation.</p>
<p dir="auto"><code>Run</code> is used to just try out the current code by temporarily downloading it into the device and executing it. Using <code>Run</code> does not switch mode - the device stays in <code>Internet mode</code>. If the device was to be reset or power cycled the code would be 'lost'.</p>
<p dir="auto">In contrast, <code>Download</code> permanently downloads the current code into the device, switches to <code>App mode</code> and executes the code. If the device was to be reset or power cycled the downloaded code would be executed again.</p>
]]></description><link>https://community.m5stack.com/post/17357</link><guid isPermaLink="true">https://community.m5stack.com/post/17357</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 01 May 2022 19:45:05 GMT</pubDate></item></channel></rss>
