<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I2CHomeAssistant Gateway]]></title><description><![CDATA[<p dir="auto">I'm well on my way to having a app for esp32(Your epaper offering at the moment), that can drive a large number of i2c sensors, currently your relay modules, and i2c Thermistors as well, and planning to add more.</p>
<p dir="auto">In addition Im planning virtual thermostats, which can watch temp sensors, and control local/remote devices, with auto updates to Home Assistant.</p>
<p dir="auto">While Im writing this generally, it makes a great multi-zone radiant heat controller. (Im using it as a 8 zone heating system.</p>
<p dir="auto">I've already got it talking to HomeAssistant, auto registering sensors, and sending updates, as well as controlling relays. All auto discovered. I've designed it for auto update as well over the network, and adding more configurabilility to it.</p>
<p dir="auto">Just discovery your 10Amp relays with esp32, so plan to add support for them(By doing a mini version of the app).<br />
And I saw your lcd driver, which could be used as a display. (Single grove port, so bigger switch would be useful.</p>
<p dir="auto">I'd love to see a couple of things:</p>
<li>A TCA9548A based i2c switch with settable address. I already have support for multiple switches if you can set the address. This really would help on devices with less grove ports (Even 1 is good).</li>
<li>A 10 Amp Solid State Relay for 110-220VAC</li>
]]></description><link>https://community.m5stack.com/topic/4265/i2chomeassistant-gateway</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 11:29:09 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4265.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 May 2022 23:02:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to I2CHomeAssistant Gateway on Tue, 17 May 2022 21:20:15 GMT]]></title><description><![CDATA[<p dir="auto">Ok, will order the "new" version when its back in stock.</p>
]]></description><link>https://community.m5stack.com/post/17514</link><guid isPermaLink="true">https://community.m5stack.com/post/17514</guid><dc:creator><![CDATA[glennswest]]></dc:creator><pubDate>Tue, 17 May 2022 21:20:15 GMT</pubDate></item><item><title><![CDATA[Reply to I2CHomeAssistant Gateway on Tue, 17 May 2022 21:14:42 GMT]]></title><description><![CDATA[<p dir="auto">That helps a bit.<br />
Sad oh its 6 ports, but least thats useable.<br />
A dip switch would be better.<br />
Next version do 8 ports, and a dipswitch<br />
TCA9548A is perfect, Im using it now.</p>
]]></description><link>https://community.m5stack.com/post/17513</link><guid isPermaLink="true">https://community.m5stack.com/post/17513</guid><dc:creator><![CDATA[glennswest]]></dc:creator><pubDate>Tue, 17 May 2022 21:14:42 GMT</pubDate></item><item><title><![CDATA[Reply to I2CHomeAssistant Gateway on Wed, 04 May 2022 12:19:20 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/glennswest" aria-label="Profile: glennswest">@<bdi>glennswest</bdi></a></p>
<p dir="auto">the TCA9548A based <a href="https://docs.m5stack.com/en/unit/pahub" target="_blank" rel="noopener noreferrer nofollow ugc">PaHub</a> (and its successor) allows to change its I2C address via three solder bridges. Available addresses are  0x70-0x77. Or am I missing something?</p>
]]></description><link>https://community.m5stack.com/post/17393</link><guid isPermaLink="true">https://community.m5stack.com/post/17393</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 04 May 2022 12:19:20 GMT</pubDate></item></channel></rss>
