<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UIFlow 1.9.7]]></title><description><![CDATA[<h3>v1.9.7</h3>
<h4>new features:</h4>
<li>
<p dir="auto">ZH-CN:</p>
<li>UNIT BUZZER 支持</li>
<li>MODULE COM.X GSM 支持</li>
</li>
<li>
<p dir="auto">EN:</p>
<li>UNIT BUZZER support</li>
<li>MODULE COM.X support</li>
</li>
<h4>Bug fix:</h4>
<li>
<li>UNIT DDS 错误修复</li>
<li>NB-IOT &amp; DTU NB-IOT CoAP 错误修复</li>
<li>M5PAPER 图像和矩形 错误修复</li>
</li>
<li>
<li>UNIT DDS bug fix.</li>
<li>NB-IOT &amp; DTU NB-IOT CoAP bug fix.</li>
<li>M5PAPER image and rectangle bug fix.</li>
</li>
]]></description><link>https://community.m5stack.com/topic/4280/uiflow-1-9-7</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 06:48:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4280.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 May 2022 11:15:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UIFlow 1.9.7 on Thu, 26 May 2022 22:23:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys</p>
<p dir="auto">in UiFlow the <a href="https://docs.m5stack.com/en/base/iot_base_catm" target="_blank" rel="noopener noreferrer nofollow ugc">IoTBaseCatM</a> module can only be used if a SIM card has been inserted. In other words the non IoT related ports (e.g. Modbus) cannot be used w/o SIM card inserted. The reason for that is that as part of the initialization <code>catmiot = module.get(module.CATMIOT)</code> an <code>AT+CPIN?</code> command is sent every 6 seconds forever since w/o SIM card inserted the response from the SIM7080 is <code>ERROR</code>.</p>
]]></description><link>https://community.m5stack.com/post/17571</link><guid isPermaLink="true">https://community.m5stack.com/post/17571</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 26 May 2022 22:23:27 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.9.7 on Fri, 20 May 2022 06:12:01 GMT]]></title><description><![CDATA[<p dir="auto">Can you implement the LVGL image resize routines as blocks please?</p>
]]></description><link>https://community.m5stack.com/post/17534</link><guid isPermaLink="true">https://community.m5stack.com/post/17534</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 20 May 2022 06:12:01 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.9.7 on Fri, 13 May 2022 18:10:04 GMT]]></title><description><![CDATA[<p dir="auto">Not a bug per say but more of a visual suggestion.<br />
The last block(Get Label Width) in the core2's LVGL Table block needs moving about 5 pixels in to light up with the other blocks.</p>
<p dir="auto"><img src="/assets/uploads/files/1652465372491-screenshot-2022-05-13-at-19.07.04-resized.png" alt="0_1652465370649_Screenshot 2022-05-13 at 19.07.04.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/17482</link><guid isPermaLink="true">https://community.m5stack.com/post/17482</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 13 May 2022 18:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.9.7 on Wed, 11 May 2022 18:06:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/m5stack" aria-label="Profile: m5stack">@<bdi>m5stack</bdi></a><br />
please support MODULE COM.X LTE DATA in a next firmware release.</p>
]]></description><link>https://community.m5stack.com/post/17472</link><guid isPermaLink="true">https://community.m5stack.com/post/17472</guid><dc:creator><![CDATA[luis]]></dc:creator><pubDate>Wed, 11 May 2022 18:06:47 GMT</pubDate></item><item><title><![CDATA[Reply to UIFlow 1.9.7 on Wed, 11 May 2022 09:58:07 GMT]]></title><description><![CDATA[<p dir="auto">Could it be that the firmware update for 1.9.7 is not yet released? If so, when will this be the case? Or is there a possibility to revert the version of uiFlow to 1.9.6 which I am not aware of?</p>
]]></description><link>https://community.m5stack.com/post/17468</link><guid isPermaLink="true">https://community.m5stack.com/post/17468</guid><dc:creator><![CDATA[GertschAlt]]></dc:creator><pubDate>Wed, 11 May 2022 09:58:07 GMT</pubDate></item></channel></rss>
