<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 with ADC does a reset]]></title><description><![CDATA[<p dir="auto">Hello everybody<br />
I measure the voltage of a 3.2V LiFePo4 cell of a solar battery on a Fire with the ADC unit via a voltage divider (2x15kOhm).<br />
When the sun comes out, the M5 sometimes resets...<br />
What can be the reason?<br />
Greetings Felix</p>
]]></description><link>https://community.m5stack.com/topic/4285/m5-with-adc-does-a-reset</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 18:12:22 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4285.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 09 May 2022 15:32:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 with ADC does a reset on Wed, 11 May 2022 05:33:00 GMT]]></title><description><![CDATA[<p dir="auto">what's the voltage when the sun comes out?<br />
you would be better of using a VMeter unit instead of the adc to measure voltage as under high sun it could be overloading the 3,3v max input pin causing the reset.</p>
<p dir="auto"><a href="https://shop.m5stack.com/collections/m5-sensor/products/voltmeter-unit-ads1115" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/collections/m5-sensor/products/voltmeter-unit-ads1115</a></p>
<p dir="auto"><img src="https://cdn.shopify.com/s/files/1/0056/7689/2250/products/1_f984ea27-d5fd-4a7b-89f6-9d62de461d86_1200x1200.jpg?v=1600647920" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://community.m5stack.com/post/17467</link><guid isPermaLink="true">https://community.m5stack.com/post/17467</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Wed, 11 May 2022 05:33:00 GMT</pubDate></item></channel></rss>
