<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Atom Switch TX&#x2F;RX Pins]]></title><description><![CDATA[<p dir="auto">Hello...  I have an ATOM-HUB SWITCH and I see on the label there are Rx(33) and Tx(23) pins available.  I assume these are hardware serial pins that are available for use but I can't figure out how to connect wires to these pins.  There are two holes at the end of the Switch where the label indicates the pins to be but I can't see how I would connect to them.  Do I need to open up the Switch case to access them?</p>
<p dir="auto">Thanks,</p>
<p dir="auto">Greg</p>
]]></description><link>https://community.m5stack.com/topic/4290/atom-switch-tx-rx-pins</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 02:46:12 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4290.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 May 2022 13:46:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Atom Switch TX&#x2F;RX Pins on Wed, 11 May 2022 19:11:44 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> , I did notice that too so I used continuity tester to see if andy of the RS-485 terminal screws were directly connected to the header pins that connect to the Atom's 33/23 pins I did't detect any continuity.  I want to connect a Nextion Display that uses a Serial connection to the Atom Switch and was hoping to utilize Pins 33/23.  I'm thinking I may need to purchase something like the MAX485 RS-485 module to attach to the Nextion display and run my serial connection over this RS-485 connection.  Think I have some reading to do. ;)</p>
]]></description><link>https://community.m5stack.com/post/17473</link><guid isPermaLink="true">https://community.m5stack.com/post/17473</guid><dc:creator><![CDATA[Uzr66]]></dc:creator><pubDate>Wed, 11 May 2022 19:11:44 GMT</pubDate></item><item><title><![CDATA[Reply to Atom Switch TX&#x2F;RX Pins on Wed, 11 May 2022 16:46:11 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/uzr66" aria-label="Profile: Uzr66">@<bdi>Uzr66</bdi></a></p>
<p dir="auto">from what I can tell from the <a href="https://docs.m5stack.com/en/atom/atomhub_switch_d" target="_blank" rel="noopener noreferrer nofollow ugc">ATOM HUB SwitchD schematic</a> those two GPIOs (33 and 23) are used for the RS485.</p>
]]></description><link>https://community.m5stack.com/post/17470</link><guid isPermaLink="true">https://community.m5stack.com/post/17470</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 11 May 2022 16:46:11 GMT</pubDate></item></channel></rss>
