<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack core2 communicate with ROS]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I am trying to use M4Stack core2 to communicate with the ROS,<br />
to be detailed, core2 sends and receives data through serial port with ROS.</p>
<p dir="auto">but it seems to fail to 'shake hand' with ROS, errors are like</p>
<p dir="auto">'<br />
~/catkin_ws$ rosrun rosserial_python serial_node.py /dev/ttyACM0<br />
[INFO] [1652882151.845943]: ROS Serial Python Node<br />
[INFO] [1652882151.860072]: Connecting to /dev/ttyACM0 at 57600 baud<br />
[INFO] [1652882153.969811]: Requesting topics...<br />
[ERROR] [1652882168.974206]: Unable to sync with device; possible link problem or link software version mismatch such as hydro rosserial_python with groovy Arduino<br />
[INFO] [1652882168.978350]: Requesting topics...</p>
anyone has clues on this, eny examples or demos on this?</p>
<p dir="auto">thank you in advance.</p>
]]></description><link>https://community.m5stack.com/topic/4305/m5stack-core2-communicate-with-ros</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:29:57 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4305.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 May 2022 14:01:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack core2 communicate with ROS on Fri, 27 May 2022 03:40:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lishengkkk" aria-label="Profile: lishengkkk">@<bdi>lishengkkk</bdi></a> Hi there, please check if the baud rate of both sides match (you can also try to change the baud rate, such as the common 115200). If it's a UART via separate wiring. Please make sure TX RX is connected correctly.</p>
]]></description><link>https://community.m5stack.com/post/17576</link><guid isPermaLink="true">https://community.m5stack.com/post/17576</guid><dc:creator><![CDATA[M5Stack_AG]]></dc:creator><pubDate>Fri, 27 May 2022 03:40:18 GMT</pubDate></item></channel></rss>
