<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PoEsp32 Module with Uiflow &#x2F; Micropython]]></title><description><![CDATA[<p dir="auto">Hi - after about an hour of searching I can't find any documentation on getting the PoEsp32 module active on a LAN.  The link light is on, the check device statement returns 1, but check ethernet connection returns 0.</p>
<p dir="auto">Would really appreciate anyone who can point me at documents or sample code.</p>
<p dir="auto">Thanks!!</p>
]]></description><link>https://community.m5stack.com/topic/4314/poesp32-module-with-uiflow-micropython</link><generator>RSS for Node</generator><lastBuildDate>Tue, 28 Apr 2026 23:56:31 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4314.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 May 2022 01:44:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PoEsp32 Module with Uiflow &#x2F; Micropython on Wed, 25 May 2022 07:30:15 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/treadbrook" aria-label="Profile: Treadbrook">@<bdi>Treadbrook</bdi></a></p>
<p dir="auto">in my experience the link light only indicates that there is an electrical connection between two Ethernet devices. The link light, however, does not give an indication about whether a device has either a static IP address or received an IP address from a DHCP server. In other words when I connect my POESP32 to a switch where the switch has no further connections (and therefore there is no DHCP server) the link light lights up, but <code>check Ethernet connection</code> returns <code>false</code>. This leads me to think that <code>check Ethernet connection</code> also checks for an IP address and not only for a link.</p>
<p dir="auto">I suggest you try to connect your POESP32, as a test, to your router directly and / or check on your router whether the POESP32 is listed in its DHCP lease list and has received an IP address.</p>
<p dir="auto">Note: if you are in a corporate network environment it is possible that the network administrator has setup port security which means an Ethernet device can only participate in that network after it has been whitelisted by said network administrator.</p>
<p dir="auto">Regarding documentation - I assume you've seen this <a href="https://docs.m5stack.com/en/unit/poesp32" target="_blank" rel="noopener noreferrer nofollow ugc">page</a>?</p>
]]></description><link>https://community.m5stack.com/post/17557</link><guid isPermaLink="true">https://community.m5stack.com/post/17557</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 25 May 2022 07:30:15 GMT</pubDate></item><item><title><![CDATA[Reply to PoEsp32 Module with Uiflow &#x2F; Micropython on Wed, 25 May 2022 05:43:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> thanks, I've checked that and the unit has a link light, so I can see that the switch port and cable are all good.  There does seem to be an awful lack of documentation on these things!</p>
]]></description><link>https://community.m5stack.com/post/17556</link><guid isPermaLink="true">https://community.m5stack.com/post/17556</guid><dc:creator><![CDATA[Treadbrook]]></dc:creator><pubDate>Wed, 25 May 2022 05:43:07 GMT</pubDate></item><item><title><![CDATA[Reply to PoEsp32 Module with Uiflow &#x2F; Micropython on Tue, 24 May 2022 07:44:08 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/treadbrook" aria-label="Profile: Treadbrook">@<bdi>Treadbrook</bdi></a></p>
<p dir="auto">sorry, I don't have any additional documentation or sample code.</p>
<p dir="auto">That said, in my tests <code>check Ethernet connection</code> only is <code>true</code> if POESP32 has received an IP address via DHCP. Maybe check you Ethernet cable and/or make sure POESP32 is connected to a network with an active DHCP server.</p>
]]></description><link>https://community.m5stack.com/post/17550</link><guid isPermaLink="true">https://community.m5stack.com/post/17550</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 24 May 2022 07:44:08 GMT</pubDate></item></channel></rss>
