<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[First Project, GPS and LoRa: Shopping Cart Check?]]></title><description><![CDATA[<p dir="auto">Aside from playing with a few M5 sticks I collected over the last couple of years, I have not done much in this ecosystem.  I know, heresy!</p>
<p dir="auto">I do have a project where the modular approach and portability would be ideal, so before I order parts I want to make sure all of these are compatible.  Basically, it will be a data collection device some distance from my house, sending data back to a device (probably an RPi) using LoRa.  I am looking at:</p>
<li><a href="https://shop.m5stack.com/products/gps-module?variant=16804773003354" target="_blank" rel="noopener noreferrer nofollow ugc">M5Stack Core2 ESP32 IoT Development Kit</a></li>
<li><a href="https://shop.m5stack.com/products/gps-module?variant=16804773003354" target="_blank" rel="noopener noreferrer nofollow ugc">GPS Module with Internal &amp; External Antenna (u-blox NEO-M8N)</a></li>
<li><a href="https://shop.m5stack.com/products/proto-module?variant=16804775198810" target="_blank" rel="noopener noreferrer nofollow ugc">Proto Module with Extension &amp; Bus Socket</a></li>
<li><a href="https://shop.m5stack.com/products/battery-module-13-2-1500mah?variant=42784887898369" target="_blank" rel="noopener noreferrer nofollow ugc">Battery Module 13.2 (1500mAh)</a></li>
<li><a href="https://shop.m5stack.com/products/lora-module-868mhz?variant=31093175910490" target="_blank" rel="noopener noreferrer nofollow ugc">LoRa Module( 868MHz ) </a> (is this the right one for the US?  I don't see a 915 MHz variant)</li>
<p dir="auto">I found <a href="https://forum.m5stack.com/topic/239/howto-m5stack-with-gps-gsm-and-lora-all-at-the-same-time" target="_blank" rel="noopener noreferrer nofollow ugc">an article</a> where most of these are demonstrated together.  Do these all seem compatible with each other?</p>
<p dir="auto">So, gut check, is there <em>anything else</em> I need (aside from the sensors and RPi) if this is really my first serious foray into this ecosystem?</p>
<p dir="auto">Final stupid question:  How is the battery charged?  USB or something else?</p>
]]></description><link>https://community.m5stack.com/topic/4364/first-project-gps-and-lora-shopping-cart-check</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 10:22:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4364.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Jun 2022 15:32:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to First Project, GPS and LoRa: Shopping Cart Check? on Fri, 17 Jun 2022 15:08:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> thank you again.  That helps me get organized.</p>
]]></description><link>https://community.m5stack.com/post/17745</link><guid isPermaLink="true">https://community.m5stack.com/post/17745</guid><dc:creator><![CDATA[lbussy]]></dc:creator><pubDate>Fri, 17 Jun 2022 15:08:58 GMT</pubDate></item><item><title><![CDATA[Reply to First Project, GPS and LoRa: Shopping Cart Check? on Thu, 16 Jun 2022 18:58:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/lbussy" aria-label="Profile: lbussy">@<bdi>lbussy</bdi></a></p>
<p dir="auto">the battery module has no USB port and no charger IC. It gets charged from the M5Core2 (using the charger IC within M5Core2) when M5Core2 is powered via USB.</p>
<p dir="auto">I do not have that LoRa module so I am afraid I cannot help you with questions related to that. Sorry.</p>
]]></description><link>https://community.m5stack.com/post/17742</link><guid isPermaLink="true">https://community.m5stack.com/post/17742</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 16 Jun 2022 18:58:03 GMT</pubDate></item><item><title><![CDATA[Reply to First Project, GPS and LoRa: Shopping Cart Check? on Thu, 16 Jun 2022 16:26:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> I appreciate the reply.  I guess I should state my question a different way:</p>
<p dir="auto">Given that <em>I believe</em> the GPIO do not conflict based on the <a href="https://forum.m5stack.com/topic/239/howto-m5stack-with-gps-gsm-and-lora-all-at-the-same-time" target="_blank" rel="noopener noreferrer nofollow ugc">referenced article</a>, and with the caveat that power consumption and battery life is not yet a concern, does that stack look "complete" enough to get a "hello world" LoRa communication connection going between the M5 and a LoRa gateway?</p>
<p dir="auto">I don't have a pile of parts and pieces from this ecosystem laying about, so I primarily want to know if that seems complete enough to power itself (however briefly) and simply send LoRa messages to a gateway.</p>
<p dir="auto">This remains a question.  Is there a charger for the battery module or is it a USB connection?  You said that the Core2 has a built-in battery so that is helpful, thank you.</p>
]]></description><link>https://community.m5stack.com/post/17740</link><guid isPermaLink="true">https://community.m5stack.com/post/17740</guid><dc:creator><![CDATA[lbussy]]></dc:creator><pubDate>Thu, 16 Jun 2022 16:26:46 GMT</pubDate></item><item><title><![CDATA[Reply to First Project, GPS and LoRa: Shopping Cart Check? on Wed, 15 Jun 2022 19:23:36 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/lbussy" aria-label="Profile: lbussy">@<bdi>lbussy</bdi></a></p>
<p dir="auto">you probably won't get an authoritative answer here for a rather complex project like this.<br />
But you could break it into smaller tasks and make some preliminary checks yourself.</p>
<li>for instance check if the modules you want to stack do not have interfering GPIOs</li>
<li>and if enough GPIOs are left to connect all the sensors you want</li>
<li>or with an M5Core2 alone you could get an idea if the battery life is what you expect (the M5Core2 has a built in battery.)</li>
<li>if you already have some sensors, check if the work with the M5Core2</li>
<li>if you add the Lora Module you could check the Lora communication between M5Core2 and RPi. (Assuming you already have the RPi and whatever Lora shield is needed on that end.)</li>
<p dir="auto">Again, the above is just a suggestion and is about how I'd tackle a project like this.</p>
]]></description><link>https://community.m5stack.com/post/17734</link><guid isPermaLink="true">https://community.m5stack.com/post/17734</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 15 Jun 2022 19:23:36 GMT</pubDate></item><item><title><![CDATA[Reply to First Project, GPS and LoRa: Shopping Cart Check? on Wed, 15 Jun 2022 13:28:12 GMT]]></title><description><![CDATA[<p dir="auto">Can anyone tell me if I am off on the wrong track or wasting money here for a remote LoRa device?</p>
]]></description><link>https://community.m5stack.com/post/17730</link><guid isPermaLink="true">https://community.m5stack.com/post/17730</guid><dc:creator><![CDATA[lbussy]]></dc:creator><pubDate>Wed, 15 Jun 2022 13:28:12 GMT</pubDate></item></channel></rss>
