<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Touch get wrong X and Y values more you go away from display center]]></title><description><![CDATA[<p dir="auto">M5.Touch get wrong X and Y values more you go away from display center. The same problem there is with M5Core2 and M5Unified.<br />
How to fix it? With this type of issue the display touch is compliteli useless. X and Y are not centered with the touch point.</p>
]]></description><link>https://community.m5stack.com/topic/4366/touch-get-wrong-x-and-y-values-more-you-go-away-from-display-center</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 00:10:46 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4366.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 15 Jun 2022 14:24:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Touch get wrong X and Y values more you go away from display center on Wed, 15 Jun 2022 16:25:14 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/gmg" aria-label="Profile: GMG">@<bdi>GMG</bdi></a></p>
<p dir="auto">care to share some code which exhibits the issue you are describing?</p>
]]></description><link>https://community.m5stack.com/post/17733</link><guid isPermaLink="true">https://community.m5stack.com/post/17733</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 15 Jun 2022 16:25:14 GMT</pubDate></item></channel></rss>
