<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AXP192 library SetChargeCurrent in M5StickC but not in M5StickCPlus]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I'm using M5StickCplus and BugC for my project.<br />
We some how made a automatic charging system with a wireless pads.</p>
<p dir="auto">But charging time takes quite long, and I found "SetChargeCurrent" but only in M5StickC, not Plus.</p>
<p dir="auto">Just moving library file doesn't work.</p>
<p dir="auto">Is there any register reference?<br />
or plan to get this SetChargeCurrent back?</p>
<p dir="auto">Thank you for reading.</p>
]]></description><link>https://community.m5stack.com/topic/4395/axp192-library-setchargecurrent-in-m5stickc-but-not-in-m5stickcplus</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 18:45:23 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4395.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Jun 2022 14:14:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AXP192 library SetChargeCurrent in M5StickC but not in M5StickCPlus on Fri, 24 Jun 2022 17:16:24 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/kazokutchi" aria-label="Profile: kazokutchi">@<bdi>kazokutchi</bdi></a></p>
<p dir="auto">From below comment I assume M5Stack engineers decided to not include the <code>SetChargerCurrent()</code> function for M5StickCPlus.</p>
<p dir="auto"><em>// Not recommend to set charge current &gt; 100mA, since Battery is only 80mAh.<br />
// more then 1C charge-rate may shorten battery life-span.</em></p>
<p dir="auto">That said, have you tired to only copy the function by itself into the corresponding AXP192.cpp file of the M5StickCPlus library?</p>
]]></description><link>https://community.m5stack.com/post/17816</link><guid isPermaLink="true">https://community.m5stack.com/post/17816</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 24 Jun 2022 17:16:24 GMT</pubDate></item></channel></rss>
