<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Multiple M020 USB modules stacked?]]></title><description><![CDATA[<p dir="auto">Hi, can you use multiple M020 USB modules with M5Stack Fire? It uses SPI interface.</p>
]]></description><link>https://community.m5stack.com/topic/4442/multiple-m020-usb-modules-stacked</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 14:47:30 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4442.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Jul 2022 09:39:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Multiple M020 USB modules stacked? on Mon, 18 Jul 2022 21:03:53 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/cyberluke" aria-label="Profile: cyberluke">@<bdi>cyberluke</bdi></a></p>
<p dir="auto">not without hardware modification, I think. While SPI uses some signals (SCK, MISO, MOSI) in parallel for all SPI slaves, there is one signal for each SPI slave so it can be selected. In other words if you stack multiple M020 USB modules (w/o hardware modification) all of them would share the same select signal and therefore react at the same time (which is not what you want.)</p>
]]></description><link>https://community.m5stack.com/post/18001</link><guid isPermaLink="true">https://community.m5stack.com/post/18001</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 18 Jul 2022 21:03:53 GMT</pubDate></item></channel></rss>
