<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cat-M1, and Cat-M1+GNSS breaks core&#x2F;atom]]></title><description><![CDATA[<p dir="auto">Whenever I plug a Cat-M1 module (Including Cat-M1+GNSS) into a core it refuses to turn on even when plugged in, and when I plugged it into an AtomU the computer the AtomU was plugged into momentarily showed a blank screen and didn’t accept input, in a StickC-Plus it worked fine on startup but anytime I ran a program, It just showed a blank screen. I’m not sure if this is a power draw issue, user error, bad manufacturing (but I wouldn’t expect that from M5), or something else.</p>
]]></description><link>https://community.m5stack.com/topic/4489/cat-m1-and-cat-m1-gnss-breaks-core-atom</link><generator>RSS for Node</generator><lastBuildDate>Fri, 08 May 2026 14:38:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4489.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Aug 2022 07:11:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cat-M1, and Cat-M1+GNSS breaks core&#x2F;atom on Sat, 06 Aug 2022 05:04:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> plugging it into a 12VDC 3A power supply makes it work fine on all of my devices, so it was just power draw issue.</p>
]]></description><link>https://community.m5stack.com/post/18203</link><guid isPermaLink="true">https://community.m5stack.com/post/18203</guid><dc:creator><![CDATA[HWTaro9]]></dc:creator><pubDate>Sat, 06 Aug 2022 05:04:40 GMT</pubDate></item><item><title><![CDATA[Reply to Cat-M1, and Cat-M1+GNSS breaks core&#x2F;atom on Wed, 03 Aug 2022 18:16:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/hwtaro9" aria-label="Profile: HWTaro9">@<bdi>HWTaro9</bdi></a></p>
<p dir="auto">I don't have the Cat-M1+GNSS module so I cannot test myself. But yes, what you are describing with the various M5Stack cores sounds either like a power draw issue or a defective module.</p>
<p dir="auto">Have you tried to power the Cat-M1+GNSS module with its own power supply instead of relying on whatever the USB port can deliver?</p>
]]></description><link>https://community.m5stack.com/post/18183</link><guid isPermaLink="true">https://community.m5stack.com/post/18183</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 03 Aug 2022 18:16:10 GMT</pubDate></item></channel></rss>
