<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How change add QMP6988 from 0x70 to 0x56?]]></title><description><![CDATA[<p dir="auto">Hi all guys.</p>
<p dir="auto">I will explain my problem right away. Through arduino I am trying to connect several sensors including the ENV3 to the PaHUB. But with the ENV3 I am experiencing a communication problem this is because QMP6988 and PaHUB communicate on the same address and this does not allow my M5Stickc Plus to receive the pressure value. Is there any way to change the communication address of the QMP6988?<br />
Thank you in advance,<br />
Sincerely<br />
Nicholas.</p>
]]></description><link>https://community.m5stack.com/topic/4494/how-change-add-qmp6988-from-0x70-to-0x56</link><generator>RSS for Node</generator><lastBuildDate>Thu, 07 May 2026 10:22:30 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4494.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Aug 2022 13:32:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How change add QMP6988 from 0x70 to 0x56? on Wed, 12 Apr 2023 08:38:50 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/gunnm" aria-label="Profile: gunnm">@<bdi>gunnm</bdi></a></p>
<p dir="auto">yes, that is my understanding from reading the datasheet. The I2C address can only be changed via hardware.</p>
]]></description><link>https://community.m5stack.com/post/20584</link><guid isPermaLink="true">https://community.m5stack.com/post/20584</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 12 Apr 2023 08:38:50 GMT</pubDate></item><item><title><![CDATA[Reply to How change add QMP6988 from 0x70 to 0x56? on Wed, 12 Apr 2023 06:20:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> said in <a href="/post/20578">How change add QMP6988 from 0x70 to 0x56?</a>:</p>
<p dir="auto">Hello guys<br />
According to the datasheet in I2C mode pin 5 selects the address. According to the schematic by default it is connected to GND (=0x70) and in order to change the address to 0x56 you would need to connect it to VDDIO (aka 3.3 V).<br />
I don't have an ENV III so I don't know if pin 5 is accessible or not.<br />
Thanks<br />
<p dir="auto">Hello Felix</p>
<p dir="auto">Thanks for the answer. Do I understand correctly that it can only be changed via hardware? So not via a software like Arduino IDE?</p>
<p dir="auto">Greetings</p>
]]></description><link>https://community.m5stack.com/post/20583</link><guid isPermaLink="true">https://community.m5stack.com/post/20583</guid><dc:creator><![CDATA[gunnm]]></dc:creator><pubDate>Wed, 12 Apr 2023 06:20:40 GMT</pubDate></item><item><title><![CDATA[Reply to How change add QMP6988 from 0x70 to 0x56? on Tue, 11 Apr 2023 19:48:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys</p>
<p dir="auto">According to the datasheet in I2C mode pin 5 selects the address. According to the <a href="https://docs.m5stack.com/en/unit/envIII" target="_blank" rel="noopener noreferrer nofollow ugc">schematic</a> by default it is connected to GND (=0x70) and in order to change the address to 0x56 you would need to connect it to VDDIO (aka 3.3 V).</p>
<p dir="auto">I don't have an ENV III so I don't know if pin 5 is accessible or not.</p>
]]></description><link>https://community.m5stack.com/post/20578</link><guid isPermaLink="true">https://community.m5stack.com/post/20578</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 11 Apr 2023 19:48:43 GMT</pubDate></item><item><title><![CDATA[Reply to How change add QMP6988 from 0x70 to 0x56? on Tue, 11 Apr 2023 06:42:20 GMT]]></title><description><![CDATA[<p dir="auto">Hello<br />
Have you or anyone else found a solution? Would be glad to have it. Thanks.<br />
Greetings</p>
]]></description><link>https://community.m5stack.com/post/20573</link><guid isPermaLink="true">https://community.m5stack.com/post/20573</guid><dc:creator><![CDATA[gunnm]]></dc:creator><pubDate>Tue, 11 Apr 2023 06:42:20 GMT</pubDate></item></channel></rss>
