<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Just a single M5Stack Plus-Module and no idea what to do]]></title><description><![CDATA[<p dir="auto">Ahoi!</p>
<p dir="auto">About me:<br />
I'm a beginner with all thinks electronics. I've soldered some stuff, can program in a few languages and had some success with arduino and LED strip programming with the Arduino IDE</p>
<p dir="auto">About the problem:<br />
I came into posession of a M5Stack Module Plus (BN 2108264). Mainly, because I wanted a ready solution for a accumulator including loading-electronics.<br />
No idea why I decided to go for that, especially without any clue what this M5 stuff is about.</p>
<p dir="auto">Now I'm sitting here with this module and no idea what to do. How can I program this module? It says, that it contains a MEGA328. I'm also unable to get a serial connection. I have a bootleg pl2303hxa USB/UART cable, which I have successfully used on an Raspberry about 6-8 years ago. Tried putty and the m5burner to connect to device but no success. I tried both ports on the module. Why? Because there's a sticker that labels port A as UART and port B as GPIO. Underneath the sticker, the labelling is reversed.<br />
Due to form factor of my cable, I've connected TX/RX to the respective pins on the ports and GND and VCC to the pinout-bar.</p>
<p dir="auto">I've tried to understand what I could do from some google results and M5 videos on YT, but I'm totally lost.<br />
So, well, now I'm here. Asking for help on what I can do, or maybe even what I can't do. Any help is appreciated.</p>
<p dir="auto">Looking forward to your input!</p>
]]></description><link>https://community.m5stack.com/topic/4500/just-a-single-m5stack-plus-module-and-no-idea-what-to-do</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 02:26:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4500.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Aug 2022 08:53:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Just a single M5Stack Plus-Module and no idea what to do on Thu, 04 Aug 2022 14:11:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/srmobar" aria-label="Profile: srmobar">@<bdi>srmobar</bdi></a> said in <a href="/post/18191">Just a single M5Stack Plus-Module and no idea what to do</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks! Looking forward to additional tipps. My goal would be, to not require a core but to find a way to interact with it another way. If this is not possible, I concede :)<br />
I'm keen to try out different things and be it just for the sake of trying it. Can't be bad to learn a thing or two along the way</p>
<p dir="auto">While it’s designed for ‘Tara know, your not limited to M5Stack. You just need to understand the pin outs and communication method</p>
]]></description><link>https://community.m5stack.com/post/18194</link><guid isPermaLink="true">https://community.m5stack.com/post/18194</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 04 Aug 2022 14:11:44 GMT</pubDate></item><item><title><![CDATA[Reply to Just a single M5Stack Plus-Module and no idea what to do on Thu, 04 Aug 2022 12:40:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ajb2k3" aria-label="Profile: ajb2k3">@<bdi>ajb2k3</bdi></a> Thanks! Looking forward to additional tipps. My goal would be, to not require a core but to find a way to interact with it another way. If this is not possible, I concede :)<br />
]]></description><link>https://community.m5stack.com/post/18191</link><guid isPermaLink="true">https://community.m5stack.com/post/18191</guid><dc:creator><![CDATA[srmobar]]></dc:creator><pubDate>Thu, 04 Aug 2022 12:40:53 GMT</pubDate></item><item><title><![CDATA[Reply to Just a single M5Stack Plus-Module and no idea what to do on Thu, 04 Aug 2022 11:17:01 GMT]]></title><description><![CDATA[<p dir="auto">The device is intended to work with a core and I think it works over i2c. The schematics should be available on M5Stack’s web site for the pin out diagram. I’m not in the office today but I have some more formation on using it.</p>
]]></description><link>https://community.m5stack.com/post/18190</link><guid isPermaLink="true">https://community.m5stack.com/post/18190</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Thu, 04 Aug 2022 11:17:01 GMT</pubDate></item></channel></rss>
