<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core 2 Touchscreen Issues]]></title><description><![CDATA[<p dir="auto">I just received my Core2, I played with some Arduino Examples,  and the touch screen won't respond. I tried to use the M5 Burner to restore the factory firmware, and it will upload but not run (screen stays black).</p>
<p dir="auto">Here is the code from the upload of the Core2FactoryTest v1.3.1:</p>
<pre><code>--chip esp32 --port COM10 --baud 1500000 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x000 C:\Users\bridg\Desktop\packages\firmware\9ba4fa2baa3d86fa6c62d7ace46ea584.bin
esptool.py v4.1
Serial port COM10
Connecting...
Chip is ESP32-D0WDQ6-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 78:21:84:93:54:0c
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 1500000
Changed.
Configuring flash size...
Auto-detected Flash size: 16MB
Flash will be erased from 0x00000000 to 0x0017cfff...
Compressed 1560496 bytes to 916442...
Writing at 0x00000000... (1 %)
Writing at 0x00011fc0... (3 %)
Writing at 0x0001a7b5... (5 %)
Writing at 0x0001ee9b... (7 %)
Writing at 0x0002389f... (8 %)
Writing at 0x00028553... (10 %)
Writing at 0x0002f742... (12 %)
Writing at 0x0003614b... (14 %)
Writing at 0x0003df98... (16 %)
Writing at 0x00045c8a... (17 %)
Writing at 0x00051d5d... (19 %)
Writing at 0x0005f53d... (21 %)
Writing at 0x000669ba... (23 %)
Writing at 0x0006b252... (25 %)
Writing at 0x0006f66e... (26 %)
Writing at 0x00073bc5... (28 %)
Writing at 0x0007c0ed... (30 %)
Writing at 0x00086d06... (32 %)
Writing at 0x0008cd9b... (33 %)
Writing at 0x00094f97... (35 %)
Writing at 0x000a238f... (37 %)
Writing at 0x000ad126... (39 %)
Writing at 0x000bd87a... (41 %)
Writing at 0x000c39e3... (42 %)
Writing at 0x000c970d... (44 %)
Writing at 0x000ceb9b... (46 %)
Writing at 0x000d43bb... (48 %)
Writing at 0x000d9d96... (50 %)
Writing at 0x000dfad3... (51 %)
Writing at 0x000e53d0... (53 %)
Writing at 0x000eadd0... (55 %)
Writing at 0x000effa2... (57 %)
Writing at 0x000f5396... (58 %)
Writing at 0x000fa4c6... (60 %)
Writing at 0x000ffbba... (62 %)
Writing at 0x001051cc... (64 %)
Writing at 0x0010a89c... (66 %)
Writing at 0x0010fa27... (67 %)
Writing at 0x00114ddf... (69 %)
Writing at 0x0011a1d0... (71 %)
Writing at 0x0011f862... (73 %)
Writing at 0x00124b55... (75 %)
Writing at 0x00129f85... (76 %)
Writing at 0x0012f109... (78 %)
Writing at 0x001347c9... (80 %)
Writing at 0x00139f26... (82 %)
Writing at 0x0013fb53... (83 %)
Writing at 0x00145641... (85 %)
Writing at 0x0014af50... (87 %)
Writing at 0x001528e7... (89 %)
Writing at 0x0015bab5... (91 %)
Writing at 0x00161dd7... (92 %)
Writing at 0x0016709c... (94 %)
Writing at 0x0016cb43... (96 %)
Writing at 0x00172327... (98 %)
Writing at 0x0017784e... (100 %)
Wrote 1560496 bytes (916442 compressed) at 0x00000000 in 14.7 seconds (effective 847.0 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
]]></description><link>https://community.m5stack.com/topic/4512/core-2-touchscreen-issues</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 03:29:43 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4512.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Aug 2022 04:42:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core 2 Touchscreen Issues on Tue, 06 Sep 2022 18:09:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/awoodbridge" aria-label="Profile: awoodbridge">@<bdi>awoodbridge</bdi></a><br />
hello<br />
i am also facing same issue. did you get the solution ?</p>
]]></description><link>https://community.m5stack.com/post/18570</link><guid isPermaLink="true">https://community.m5stack.com/post/18570</guid><dc:creator><![CDATA[pannu]]></dc:creator><pubDate>Tue, 06 Sep 2022 18:09:04 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 Touchscreen Issues on Wed, 10 Aug 2022 07:11:41 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/awoodbridge" aria-label="Profile: awoodbridge">@<bdi>awoodbridge</bdi></a></p>
<p dir="auto">hmm is there anything in the debug log output indicating an issue with touch?</p>
]]></description><link>https://community.m5stack.com/post/18269</link><guid isPermaLink="true">https://community.m5stack.com/post/18269</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 10 Aug 2022 07:11:41 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 Touchscreen Issues on Wed, 10 Aug 2022 01:34:32 GMT]]></title><description><![CDATA[<p dir="auto">I tried that program. The screen shows up, but the screen doesn't respond to touch.</p>
]]></description><link>https://community.m5stack.com/post/18262</link><guid isPermaLink="true">https://community.m5stack.com/post/18262</guid><dc:creator><![CDATA[awoodbridge]]></dc:creator><pubDate>Wed, 10 Aug 2022 01:34:32 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 Touchscreen Issues on Tue, 09 Aug 2022 10:20:55 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/awoodbridge" aria-label="Profile: awoodbridge">@<bdi>awoodbridge</bdi></a></p>
<p dir="auto">I get the same result - blank screen. The issue is that the command to download Core2FactoryTest v1.3.1 in M5Burner is not correct for this particular binary. It loads the code to the incorrect address 0x000 - the correct address is 0x1000.</p>
<p dir="auto">I suggest you try Core2_Tools  v1.0.1 - that binary and download command work for me.</p>
]]></description><link>https://community.m5stack.com/post/18255</link><guid isPermaLink="true">https://community.m5stack.com/post/18255</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 09 Aug 2022 10:20:55 GMT</pubDate></item></channel></rss>
