<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Module and Sensor power specs]]></title><description><![CDATA[<p dir="auto">I've been looking at M5Stack modules and sensors for different application possibilities.  I know that the<br />
calculation of power consumption is complicated but it can be broken down to some degree so the<br />
information can be helpful when considering use of these products.</p>
<p dir="auto">Is there information available on power consumption for each module and sensor.  The uC mode<br />
is one piece but the regulators (glue logic) surrounding key components in each device can be<br />
determined and documented.</p>
<p dir="auto">With Battery operation in mind, sensors would be sampled at a low frequency (depends) and<br />
the processor put to sleep and when possible woken up by interrupt or timer.  These practices<br />
help reduce average power.</p>
<p dir="auto">If M5Stack published/documented this information it would be of great help in choosing whether<br />
to commit to M5Stack hardware.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/4514/m5stack-module-and-sensor-power-specs</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 16:41:35 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4514.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Aug 2022 15:30:30 GMT</pubDate><ttl>60</ttl></channel></rss>
