<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5paper: source code of the default apps?]]></title><description><![CDATA[<p dir="auto">Is the source code of the default apps for M5paper published anywhere? I think that would help me understand many of the aspects.</p>
<p dir="auto">TIA,</p>
]]></description><link>https://community.m5stack.com/topic/4519/m5paper-source-code-of-the-default-apps</link><generator>RSS for Node</generator><lastBuildDate>Wed, 29 Apr 2026 18:17:53 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4519.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Aug 2022 20:05:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5paper: source code of the default apps? on Wed, 17 Aug 2022 01:29:38 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/hamnet" aria-label="Profile: Hamnet">@<bdi>Hamnet</bdi></a></p>
<p dir="auto">it takes time for a new board to be included in Arduino and subsequently into PlatformIO. So when M5Paper came out the easiest way to create an M5Paper PlatformIO project, was to take a similar board, in this case M5Stack Fire, which was already available. (The key here is that both M5Stack Fire and M5Paper use PSRAM.) And later on, I guess, M5Stack engineers simply forgot to fix that.</p>
]]></description><link>https://community.m5stack.com/post/18358</link><guid isPermaLink="true">https://community.m5stack.com/post/18358</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 17 Aug 2022 01:29:38 GMT</pubDate></item><item><title><![CDATA[Reply to M5paper: source code of the default apps? on Mon, 15 Aug 2022 11:51:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> thank you.<br />
I've installed VS Code, and installed the PlatformIO IDE into it.<br />
Under Devices, it can see the one corresponding to the M5paper.<br />
Under Boards, it offers many of the M5 APIs, but M5paper isn't in the list.<br />
I can open the "M5Paper_FactoryTest" project; it has "board" set to "m5stack-fire".</p>
<p dir="auto">After a few false starts, it builds and installs on the device, so that's all good.</p>
<p dir="auto">Is there anything I can/should do to set the board correctly? Does it matter?</p>
]]></description><link>https://community.m5stack.com/post/18341</link><guid isPermaLink="true">https://community.m5stack.com/post/18341</guid><dc:creator><![CDATA[Hamnet]]></dc:creator><pubDate>Mon, 15 Aug 2022 11:51:58 GMT</pubDate></item><item><title><![CDATA[Reply to M5paper: source code of the default apps? on Sun, 14 Aug 2022 20:47:42 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/hamnet" aria-label="Profile: Hamnet">@<bdi>Hamnet</bdi></a></p>
<p dir="auto">for this project M5Stack engineers decided to use Visual Studio Code and PlatformIO as programming environment (instead of Arduino). Try searching with Google for <code>Arduino esp32 platformio</code> for more information.</p>
]]></description><link>https://community.m5stack.com/post/18335</link><guid isPermaLink="true">https://community.m5stack.com/post/18335</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Sun, 14 Aug 2022 20:47:42 GMT</pubDate></item><item><title><![CDATA[Reply to M5paper: source code of the default apps? on Sun, 14 Aug 2022 17:43:07 GMT]]></title><description><![CDATA[<p dir="auto">Thank you Felix <a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a>, that's very helpful.</p>
<p dir="auto">A naive question - how can I compile that back on to the device? The only mechanism I've got working to talk to it is Arduino - I see a reference to Arduino in the .ini file, but can't open it as a project in the Arduino IDE.</p>
<p dir="auto">Is there something different I need to open it in Arduino? Or do I need to use some different method altogether.</p>
<p dir="auto">Thanks again for all your assistance.</p>
]]></description><link>https://community.m5stack.com/post/18332</link><guid isPermaLink="true">https://community.m5stack.com/post/18332</guid><dc:creator><![CDATA[Hamnet]]></dc:creator><pubDate>Sun, 14 Aug 2022 17:43:07 GMT</pubDate></item><item><title><![CDATA[Reply to M5paper: source code of the default apps? on Fri, 12 Aug 2022 09:46:40 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/hamnet" aria-label="Profile: Hamnet">@<bdi>Hamnet</bdi></a></p>
<p dir="auto">this is the <a href="https://github.com/m5stack/M5Paper_FactoryTest" target="_blank" rel="noopener noreferrer nofollow ugc">firmware</a> which was initially loaded on the M5Paper.</p>
]]></description><link>https://community.m5stack.com/post/18302</link><guid isPermaLink="true">https://community.m5stack.com/post/18302</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 12 Aug 2022 09:46:40 GMT</pubDate></item></channel></rss>
