<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5 Core turns off after a few minutes using Base AAA Battery Holder]]></title><description><![CDATA[<p dir="auto">My M5 Core turns off after a few minutes using Base AAA Battery Holder. I have to press the power button to turn it on again. Is there some sort of power management taking place behind the scenes? Has anyone experienced this issue?</p>
]]></description><link>https://community.m5stack.com/topic/4569/m5-core-turns-off-after-a-few-minutes-using-base-aaa-battery-holder</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 14:20:42 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4569.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Aug 2022 13:06:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5 Core turns off after a few minutes using Base AAA Battery Holder on Thu, 22 Sep 2022 06:36:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys</p>
<p dir="auto">the M5Stack incorporates the IP5306 as power management chip which has an auto shutdown feature (under light load) when running from battery.</p>
<p dir="auto">The default light load shutdown time is set to 32 seconds. (Other options are 8, 16 and 64 seconds.) Unfortunately I do not see a register or bit in the IP5306 which would allow to turn off that feature. Also what amperage counts as light load I do not know.</p>
<p dir="auto">In my simulation my M5Stack was turned off by that feature by putting the ESP32 into light sleep for about a minute. (In light sleep the current was about 28 mA.)</p>
<p dir="auto">BTW: only turning off the screen backlight did not trigger the auto shutdown as the remaining current (about 68 mA) was still high enough I guess.</p>
<p dir="auto">If indeed the shutdown feature under light load is what turns your M5Stack off, then I guess it is dependent on the program you are running on your M5Stack and how much power it consumes at a given time.</p>
]]></description><link>https://community.m5stack.com/post/18675</link><guid isPermaLink="true">https://community.m5stack.com/post/18675</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 22 Sep 2022 06:36:19 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Core turns off after a few minutes using Base AAA Battery Holder on Wed, 21 Sep 2022 17:47:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello guys</p>
<p dir="auto">batteries fresh?</p>
]]></description><link>https://community.m5stack.com/post/18670</link><guid isPermaLink="true">https://community.m5stack.com/post/18670</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 21 Sep 2022 17:47:29 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Core turns off after a few minutes using Base AAA Battery Holder on Wed, 21 Sep 2022 16:54:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wwhite" aria-label="Profile: wwhite">@<bdi>wwhite</bdi></a> said in <a href="/post/18484">M5 Core turns off after a few minutes using Base AAA Battery Holder</a>:</p>
<p dir="auto">anyone</p>
<p dir="auto">I am experiencing the same issue. The m5stack core powers itself off after some time when running in the APP mode.  I am on v1.9.8. (shown on the LCD screen when I am on the setup screen)</p>
]]></description><link>https://community.m5stack.com/post/18669</link><guid isPermaLink="true">https://community.m5stack.com/post/18669</guid><dc:creator><![CDATA[asshutossh]]></dc:creator><pubDate>Wed, 21 Sep 2022 16:54:41 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Core turns off after a few minutes using Base AAA Battery Holder on Tue, 30 Aug 2022 05:07:21 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wwhite" aria-label="Profile: wwhite">@<bdi>wwhite</bdi></a></p>
<p dir="auto">Please show me a picture with the battery attached.</p>
]]></description><link>https://community.m5stack.com/post/18495</link><guid isPermaLink="true">https://community.m5stack.com/post/18495</guid><dc:creator><![CDATA[macsbug]]></dc:creator><pubDate>Tue, 30 Aug 2022 05:07:21 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Core turns off after a few minutes using Base AAA Battery Holder on Tue, 30 Aug 2022 04:58:36 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wwhite" aria-label="Profile: wwhite">@<bdi>wwhite</bdi></a></p>
<p dir="auto">hmm, I tried a simulation with an external power supply, set to 4 V and feeding into the BAT connection of an M5Stack running UIFlow firmware and it did not turn off or stop.</p>
<p dir="auto">Have you tried to burn a different program onto your M5Stack to see if that makes a difference?</p>
<p dir="auto">And, are the batteries fresh?</p>
]]></description><link>https://community.m5stack.com/post/18493</link><guid isPermaLink="true">https://community.m5stack.com/post/18493</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Tue, 30 Aug 2022 04:58:36 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Core turns off after a few minutes using Base AAA Battery Holder on Mon, 29 Aug 2022 22:01:35 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for responding Felix,</p>
<p dir="auto">I'm using a M5Stack.<br />
The red light on the AAA battery holder stays lit when the app stops.<br />
My program calls an api on the internet and displays 8 lines of text.<br />
The app will run nonstop when using USB power and perform as intended.</p>
<p dir="auto">WW</p>
]]></description><link>https://community.m5stack.com/post/18491</link><guid isPermaLink="true">https://community.m5stack.com/post/18491</guid><dc:creator><![CDATA[wwhite]]></dc:creator><pubDate>Mon, 29 Aug 2022 22:01:35 GMT</pubDate></item><item><title><![CDATA[Reply to M5 Core turns off after a few minutes using Base AAA Battery Holder on Mon, 29 Aug 2022 14:37:13 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/wwhite" aria-label="Profile: wwhite">@<bdi>wwhite</bdi></a></p>
<li>which M5Stack device are you using? M5Stack Base, Fire, Go or M5Core2?</li>
<li>when the M5Stack device turns off, does the RED LED of the Base AAA Battery Holder go out as well?</li>
<li>what program is running on your M5Stack device?</li>
<li>does the M5Stack device turn off as well when it is powered from USB instead of from the Base AAA Battery Holder?</li>
<p dir="auto">I don't have the Base AAA Battery Holder, but judging from the schematic I don't see anything which would auto turn off the power after a while. The DC/DC converter MP1470 used only has over current protection and thermal shutdown functionality.</p>
]]></description><link>https://community.m5stack.com/post/18485</link><guid isPermaLink="true">https://community.m5stack.com/post/18485</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Mon, 29 Aug 2022 14:37:13 GMT</pubDate></item></channel></rss>
