<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core 2 unit with M5Go2, Serial Port C and external Elechouse RFID V 1.2]]></title><description><![CDATA[<p dir="auto">On a Core 2 unit with M5Go2 bottom, I need to connect an external RFID board (Elechouse) but its not working  yet, just getting a "None" or  b'x\00' data return.</p>
<p dir="auto">The connection is UART based using Port C (Blue), Pins TXD2 14, RXD2 13 : Supports UART with 115200 data rate configured to UART2). In order to test the Core2 side I did loop configuration sending RX to TX with a jumper wire and I worte a string "Testing_Serial" by an UART write command. This worked fine. When connecting the external board I get back a string with b'x\00'. The wires to the external device are crossed TX-&gt;RX, RX&lt;-TX and the two power wires. Not sure, if there is a command sequence required to activate the data transmission and RFID data readout at the device. The board is reading tags and is blinking. Any insight are welcome.</p>
]]></description><link>https://community.m5stack.com/topic/4575/core-2-unit-with-m5go2-serial-port-c-and-external-elechouse-rfid-v-1-2</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 14:20:32 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4575.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Sep 2022 14:19:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core 2 unit with M5Go2, Serial Port C and external Elechouse RFID V 1.2 on Thu, 01 Sep 2022 17:00:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/felmue" aria-label="Profile: felmue">@<bdi>felmue</bdi></a> You are right, it seems to be a voltage mismatch. The UART requests 5V, but ESP32 delivers only 3.3V.<br />
Reading: <em>"On-board level shifter, Standard 5V TTL for I2C and UART, 3.3V TTL SPI</em>"<br />
Find more: <a href="https://manuals.plus/elechouse/pn532-nfc-rfid-module-manual#introduction" target="_blank" rel="noopener noreferrer nofollow ugc">https://manuals.plus/elechouse/pn532-nfc-rfid-module-manual#introduction</a><br />
Time to buy a M5stack reader unit and use the standard UiFlow drivers. Thanks!</p>
]]></description><link>https://community.m5stack.com/post/18517</link><guid isPermaLink="true">https://community.m5stack.com/post/18517</guid><dc:creator><![CDATA[falbriard]]></dc:creator><pubDate>Thu, 01 Sep 2022 17:00:38 GMT</pubDate></item><item><title><![CDATA[Reply to Core 2 unit with M5Go2, Serial Port C and external Elechouse RFID V 1.2 on Thu, 01 Sep 2022 15:24:04 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/falbriard" aria-label="Profile: falbriard">@<bdi>falbriard</bdi></a></p>
<p dir="auto">do you have a link to the specifications of the Elechouse RFID v1.2? The ones I found from Elechouse (which support UART) state in the specification that UART TTL interface is 5 V. While Port C power is 5 V the data lines TX and RX are only 3.3 V. Maybe that is the issue?</p>
]]></description><link>https://community.m5stack.com/post/18516</link><guid isPermaLink="true">https://community.m5stack.com/post/18516</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 01 Sep 2022 15:24:04 GMT</pubDate></item></channel></rss>
