<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cat-M or CatM+GNSS Unit not working in UIFLOW - screen stays blank - [solved]]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
i ordered a bunch of units to try out some things.</p>
<p dir="auto">When i connect the Cat-M or the CatM+GNSS to my Core2 oder StickCPlus it does not work with UIFLOW</p>
<p dir="auto">For testing, i added a Label to the screen. When i push it to the device, the label shows.<br />
Then i add the Unit. E.g. the Cat-M Modul to the device, in UIFLOW and connect the cable.<br />
When i push the code to the device ( no additional Blocks added yet, just defined the Unit ), the screen stays blank, and the label is not displayed.</p>
<p dir="auto">This behaviour is the same for the Cat-M unit, or the CatM+GNSS Unit.</p>
<p dir="auto">Any ideas what might be wrong? I have connected the Core2 via usb to a additional power source, just to be sure.</p>
<p dir="auto">I am talking about this two units:<br />
<a href="https://shop.m5stack.com/collections/m5-sensor/products/sim7080g-cat-m-nb-iot-unit" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/collections/m5-sensor/products/sim7080g-cat-m-nb-iot-unit</a><br />
or<br />
<a href="https://shop.m5stack.com/collections/m5-sensor/products/sim7080g-cat-m-nb-iot-gnss-unit-with-telec-antenna" target="_blank" rel="noopener noreferrer nofollow ugc">https://shop.m5stack.com/collections/m5-sensor/products/sim7080g-cat-m-nb-iot-gnss-unit-with-telec-antenna</a></p>
]]></description><link>https://community.m5stack.com/topic/4626/cat-m-or-catm-gnss-unit-not-working-in-uiflow-screen-stays-blank-solved</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 14:20:26 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4626.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Sep 2022 13:05:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cat-M or CatM+GNSS Unit not working in UIFLOW - screen stays blank - [solved] on Thu, 22 Sep 2022 12:45:28 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/a1development" aria-label="Profile: a1development">@<bdi>a1development</bdi></a></p>
<p dir="auto">I am glad to hear you got it working and thank you for reporting back.</p>
]]></description><link>https://community.m5stack.com/post/18679</link><guid isPermaLink="true">https://community.m5stack.com/post/18679</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 22 Sep 2022 12:45:28 GMT</pubDate></item><item><title><![CDATA[Reply to Cat-M or CatM+GNSS Unit not working in UIFLOW - screen stays blank - [solved] on Thu, 22 Sep 2022 12:06:41 GMT]]></title><description><![CDATA[<p dir="auto">Thank you all for your help.</p>
<p dir="auto">I removed the pin from my sim card and now it works :)</p>
]]></description><link>https://community.m5stack.com/post/18677</link><guid isPermaLink="true">https://community.m5stack.com/post/18677</guid><dc:creator><![CDATA[a1development]]></dc:creator><pubDate>Thu, 22 Sep 2022 12:06:41 GMT</pubDate></item><item><title><![CDATA[Reply to Cat-M or CatM+GNSS Unit not working in UIFLOW - screen stays blank - [solved] on Thu, 22 Sep 2022 02:03:46 GMT]]></title><description><![CDATA[<p dir="auto">Most of the time, if i wait about 5 minutes it works. It seems to be an initialization issue.</p>
]]></description><link>https://community.m5stack.com/post/18672</link><guid isPermaLink="true">https://community.m5stack.com/post/18672</guid><dc:creator><![CDATA[HWTaro9]]></dc:creator><pubDate>Thu, 22 Sep 2022 02:03:46 GMT</pubDate></item><item><title><![CDATA[Reply to Cat-M or CatM+GNSS Unit not working in UIFLOW - screen stays blank - [solved] on Wed, 21 Sep 2022 16:17:02 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/a1development" aria-label="Profile: a1development">@<bdi>a1development</bdi></a></p>
<p dir="auto">I think I know what might be going on. As part of the initialization the UIFlow code sends the AT command to check for a SIM PIN, e.g. <code>AT+CPIN?</code> and if it doesn't receive a <code>+CPIN: READY</code> it won't continue.</p>
<p dir="auto">Make sure you have a IoT SIM card in your Cat-M unit which has the SIM PIN disabled.</p>
]]></description><link>https://community.m5stack.com/post/18667</link><guid isPermaLink="true">https://community.m5stack.com/post/18667</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Wed, 21 Sep 2022 16:17:02 GMT</pubDate></item></channel></rss>
