<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to enter USB Mode on CORE2]]></title><description><![CDATA[<p dir="auto">How can i get to usb mode on core2 without using m5burner every time?<br />
I saw that on the original core, you could press a button (a physical one that is now a touch surface) to select start mode.<br />
Is this still possible on the core2?<br />
Thanks<br />
Aaron</p>
]]></description><link>https://community.m5stack.com/topic/4640/how-to-enter-usb-mode-on-core2</link><generator>RSS for Node</generator><lastBuildDate>Fri, 01 May 2026 14:45:37 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/4640.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 23 Sep 2022 03:29:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to enter USB Mode on CORE2 on Fri, 23 Sep 2022 13:44:21 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/aeisele55" aria-label="Profile: AEisele55">@<bdi>AEisele55</bdi></a></p>
<p dir="auto">on M5Stack you can select <em>Setup</em> - <em>Switch Mode</em> - <em>USB Mode</em> and reboot.</p>
<p dir="auto">However on M5Core2 this option is missing. <em>Setup</em> doesn't have a <em>Switch Mode</em> entry.(Tested with UIFlow firmware v1.10.6)</p>
]]></description><link>https://community.m5stack.com/post/18704</link><guid isPermaLink="true">https://community.m5stack.com/post/18704</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Fri, 23 Sep 2022 13:44:21 GMT</pubDate></item><item><title><![CDATA[Reply to How to enter USB Mode on CORE2 on Fri, 23 Sep 2022 07:22:51 GMT]]></title><description><![CDATA[<p dir="auto">When the core2 boots up it should give you the option to enter menu by pressing the touch zone.</p>
]]></description><link>https://community.m5stack.com/post/18699</link><guid isPermaLink="true">https://community.m5stack.com/post/18699</guid><dc:creator><![CDATA[ajb2k3]]></dc:creator><pubDate>Fri, 23 Sep 2022 07:22:51 GMT</pubDate></item></channel></rss>
